EOS R10
- EOS R10 Body
- Strap ER-EOSR10
- Battery Charger LC-E17
- Battery Pack LP-E17
- Battery Pack Cover
- Shoe Cover
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
More Than An Upgrade
The EOS R10 is perfect for content creators looking to take their creativity to the next level. Featuring a high-speed shooting 15 FPS mechanical shutter1,2, a 24.2 Megapixel CMOS (APS-C) sensor, and lightning fast autofocus, the EOS R10 camera brings some of the best features from the growing EOS R Series to a sleek, lightweight design.
Capture sharp photos and video
Offering high sensitivity, nuanced image quality, and fast overall performance, a 24.2 Megapixel CMOS (APS-C) sensor delivers stunning resolution to fast-action photos taken day or night. Plus, the efficient DIGIC X advanced image processor powers 4K video capture and reduces noise, so you can continuously shoot without worrying about capturing the shot.
Full features, sleek design
The easy-to-carry EOS R10 packs advanced features into a lightweight, compact design. Pair with a Canon RF-S/RF lens (or EF/EF-S lens using the Mount Adapter EF-EOS R*) for a high-performance setup that fits easily and comfortably in your hand.
Capture fast-moving subjects in brilliant detail
With a high-speed shooting 15 FPS mechanical shutter,1,2 the EOS R10 can capture the perfect moment between your subject’s movement. This is ideal for dynamic action photos such as sports, animals, cars - or life just as it happens.
Smart, speedy autofocus
Canon's Dual Pixel CMOS AF technology with people, animal,3 and vehicle subject detection lets you keep your eye on the action while it keeps your subject in crystal clear focus.
Record each clip over 30 minutes
Set up your video without worrying about it stopping after 30-minutes.4
Optimized for video
Get professional-grade 4K video on-the-go with Movie Servo AF, an autofocus system that includes subject detection and subject tracking for quicker shooting and a stronger focus.
Compatibility with full range of Canon RF-S, RF, EF, EF-S mounts*
Backwards compatible, future proof. Enjoy full compatibility with Canon’s legendary line up of lens past, present and future.
* Optional Mount Adapter EF-EOS R is required when using EF/EF-S lenses with an EOS R series camera.
1. Continuous shooting speed may be slower due to factors such as anti-flicker shooting, aperture value, or battery life.
2. Not available when Dual Pixel RAW is enabled.
3. Effectiveness varies depending on the subject. In some cases, dogs, cats or birds may not be detected, while some animals other than dogs, cats or birds may be detected.
4. Video may stop due to battery level, card capacity, or internal temperature.
| Type | Digital Single-Lens Non-Reflex AF/AE Camera Image Processor |
| Recording Medium | SD Card
| Compatible Lenses | Canon RF-S/RF Lens Group (Excluding EF, EF-S And EF-M Lenses) When Using Mount Adapter EF-EOS R: Canon EF Or EF-S Lenses (Excluding EF-M Lenses) |
| Lens Mount | Canon RF Mount | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Type | CMOS Sensor (Compatible With Dual Pixel CMOS AF) Sensor Size |
| Pixels | Effective Pixels: Approx. 24.2 Megapixels Total Pixels: Approx. 25.5 Megapixels |
| Pixel Unit | Approx. 3.72 µm Square | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Total Pixels | Approx. 25.5 Megapixels | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Aspect Ratio | 3:2 (Horizontal: Vertical) | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Color Filter System | RGB Primary Color Filters | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Low Pass Filter | Installed In Front Of The Image Sensor, Non-Detachable | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Dust Deletion Feature |
| Recording Format | Compliant To Design Rule For Camera File System 2.0 And Exif 2.31*. * Supports Time Difference Information. |
| Image Format | Still: JPEG, HEIF, RAW, Dual Pixel RAW, Raw Burst, C-RAW (CR3); Movies: ALL-I*, IPB, IPB Light * Time-Lapse Movies Only HDR Mode-Continuous Shooting Advanced Shooting Operations |
| File Size | 3:2 Aspect Ratio Large/HEIF/RAW: 6000 X 4000 Medium: 3984 X 2656 Small 1: 2979 X 1984* Small 2: 2400 X 1600 4:3 Aspect Ratio Large: 5328 X 4000* Medium: 3552 X 2664* Small 1: 2656 X 1992* Small 2: 2112 X 1600* RAW: 6000 X 4000 16:9 Aspect Ratio Large: 6000 X 3368* Medium: 3984 X 2240* Small 1: 2976 X 1680* Small 2: 2400 X 1344* RAW: 6000 X 4000 1:1 Aspect Ratio Large: 4000 X 4000 Medium: 2656 X 2656 Small 1: 1984 X 1984 Small 2: 1600 X 1600 RAW: 6000 X 4000
* Indicate An Inexact Proportion. |
| File Numbering | The Following File Numbers Can Be Set: File Numbering Methods
| Raw Jpeg Simultaneous Recording | Simultaneous Recording Of Any Combination Of RAW/C-RAW And JPEG/HEIF Image-Recording Quality Is Supported. | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Color Space | Selectable Between SRGB And Adobe RGB | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Picture Style |
| Settings |
2 Setting Method Options Include [Custom White Balance] And [Shoot To Set WB]. |
| Auto White Balance | Option Between Ambience Priority And White Priority Settings. | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Color Temperature Compensation | Blue/Amber Bias: ±9 Levels Magenta/Green Bias: ±9 Levels
| Type | OLED Color Electronic Viewfinder; Approx. 2.36 Million Dots Resolution | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Coverage | Approx. 100% Vertically And Horizontally Relative To The Shooting Image Area (With Image Quality L, At Approx. 22mm Eyepoint). | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Magnification | Approx. 0.95x / Approx. 28 Degrees (With 3:2 Display, A 50mm Lens At Infinity, -1 M--1) | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Eyepoint | Approx. 22mm (At -1 M-1 From The Eyepiece Lens End) | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Dioptric Adjustment Correction | Approx. -3.0 To + 1.0 M-1 (Dpt) | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Type | Dual Pixel CMOS AF | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Af Working Range | EV -4 To 20 (F/1.2 Lens*, Center AF Point, One-Shot AF, At Room Temperature, ISO 100) * Except RF Lenses With A Defocus Smoothing (DS) Coating. Number Of AF Zones Available For Automatic Selection Focusing Brightness Range (In Movie Recording) Subject To Detect Focus Mode Switch
| Af Point Selection |
| Metering Modes | Real-Time Metering With Image Sensor (384 [24x16 Zone Metering])
| Metering Range | Still Photo Shooting : EV -2 To 20 (At Room Temperature, ISO 100) Movie Recording: EV 0 To 20 (At Room Temperature, ISO 100) |
| Exposure Control Systems |
| Iso Speed Range | Available ISO Speeds; User-Set
User-Defined ISO Range - Still Photo Shooting
* Expanded ISO Speeds Are Noted As Being "Equivalent" To These Speeds. User-Defined Auto ISO Range - Still Photo Shooting
ISO Auto Details In Still Photo Shooting
*1 ISO 200 When [Highlight Tone Priority] Is Set To [Enable] Or [Enhanced]. |
| Exposure Compensation |
| Ae Lock |
| Type |
* Cannot Be Used In Conjunction With The Following Functions: Flash Photography, HDR Shooting, Multiple Exposures, Multi Shot Noise Reduction, AEB, HDR PQ, Anti-Flicker Shooting, Dual Pixel RAW Shooting, Digital Lens Optimizer [High]. |
| Shutter Speeds | When [Mechanical] Or [Elec. 1st- Curtain] Is Set: 1/4000-30 Sec, Bulb When [Electronic] Is Set: 1/4000-30 Sec. X-Sync Speed |
| Shutter Release | Soft-Touch Electromagnetic Release | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Self Timer | 10-Sec. Delay, 2-Sec. Delay | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Shutter Lag Time |
Based On Canon Testing Standards. Image Stabilization (IS Mode)IS Mode Overview
• Simultaneous Use Of IS Mode And Movie Digital IS Is Supported In Movie Recording. |
| Compatible Flash | Canon EX- And EL-Series Speedlites | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Flash Metering |
| Flash Exposure Compensation | ±3 Stops In 1/3- Or 1/2-Stop Increments E-TTL Balance Compatible E-TTL Speedlites Slow Sync (P/Av Modes)
Flash Function Menu Continuous Flash Control
| Drive Modes |
*1 AE, Flash Metering, And WB Do Not Change After The First Shot In Flash Photography. |
| Focusing | Dual Pixel CMOS AF II | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Exposure Compensation | ±3 Stops In 1/3- Or 1/2-Stop Increments | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Type | TFT Color, Liquid-Crystal Monitor | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Screen Monitor Size | 3.0-Inch (Screen Aspect Ratio Of 3:2) | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Pixels | Approx. 1.04 Million Dots | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Coverage | Approx. 100% Vertically/Horizontally | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Brightness Control | Manually Adjustable To One Of Seven Brightness Levels | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Interface Languages | 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, Japanese) | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Image Display Format |
| Highlight Alert | The White Areas With No Image Data Will Blink. | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Histogram | Brightness And RGB Quick Control FunctionFunction |
| Protection |
| Erase | Except Protected Images
| Compatible Printers | Images Can Be Sent Via Wi-Fi To A PictBridge-Compatible (Wireless LAN) Printer And Printed. | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Dpof | Compliant To DPOF Version 1.1 Wi-Fi®Standards Compliance Transmission Method Transition Frequency (Central Frequency) Security
Communication With A Smartphone
Remote Operation Using EOS Utility Print From Wi-Fi® Printers Send Images To A Web Service Bluetooth®Standards Compliance Transmission Method |
| Custom Functions |
| Custom Controls |
| My Menu Registration |
| Usb Terminal | Hi-Speed USB (USB 2.0) Equivalent
| Video Out Terminal | HDMI Micro OUT Terminal Type D (Resolution Switches Automatically) / CEC Not Compatible
Clean HDMI Output Microphone Input Terminal Headphone Terminal Remote Control Terminal Wireless Remote Control
Multi-Function Shoe |
| Battery | LP-E17
| Battery Check | Automatic Battery Check When The Power Switch Is Turned ON. |
| Start Up Time | Approx. 0.4 Sec.
| Dimensions W X H X D | Approx. 4.82 X 3.46 X 3.28 In. / 122.5 X 87.8 X 83.4 Mm
| Weight | Approx. 0.84 Lbs (13.48 Oz) Body Only Approx. 0.94 Lbs (15.14 Oz) With Battery,And Memory Card |
| Operating Humidity Range | 85% Or Less | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Working Temperature Range | 32-104° F / 0-40° C | ||||||||||||||||||||||||||||||||||||||||||||||||||
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
