EOS M200
- EOS M200
- EF-M 15-45mm f/3.5-6.3 IS STM
- Battery Pack LP-E12
- Battery Charger LC-E12
- Neck Strap EM-200DB
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Create limitless memories with the EOS M200 interchangeable lens camera. Equipped with a 24.1 Megapixel CMOS (APS-C) sensor, Eye Detection AF and enhanced Dual Pixel CMOS AF, the EOS M200 makes it easy to capture high-quality images and videos, all in a compact, mirrorless design. Perfect for social media sharing, the EOS M200 camera boasts 4K 24p/25p video capability, vertical video* support and built-in Wi-Fi®** and Bluetooth®*** technology — helping you relive your favorite moments. Designed for ultimate creativity, the EOS M200 camera offers simple-to-use features that let your personality shine. Explore the camera’s creative filters to add a splash of color and special effects to your images, or use the Creative Assist function to easily adjust brightness and color tone. The EOS M200 camera’s Visual Guide also provides helpful tips and tricks that make navigating the camera a breeze. For selfie-enthusiasts, this camera is on point, featuring a Self Portrait Mode and a 3.0-inch tilt-type LCD that rotates 180°, helping you capture every angle with ease. With the EOS M200 interchangeable lens camera, inspiration will always be at hand.
The EOS M200 camera lets you shoot with Dual Pixel CMOS AF for fast, accurate autofocus that helps you get the photo you want right as the moment happens. This means fast action can be captured and focus can be maintained with speed, accuracy and ease.
AF Area Coverage of Approx. 88% x 100%^
The EOS M200 camera features an expansive focus area of approx. 88% horizontal and 100% vertical when working with select EF-M lenses (and select EF and EF-S lenses with the optional EF-EOS M adapter). With other EF-M (or EF and EF-S) lenses, the M200 camera focuses approx. 80% horizontally and 80% vertically. This means fast and impressive focusing even if your subject is way off center.
^ When shooting still photos. Actual coverage varies depending on the lens in use.
The EOS M200 camera features a powerful 24.1 Megapixel CMOS (APS-C) sensor that can capture high-resolution images and beautiful 4K video. Take photos and videos with fine details and dynamic, rich colors from the deepest reds to emerald greens to lush blues and purples. Simply turn the camera on and feel confident that the results will be stunning.
DIGIC 8 Image Processor
The DIGIC 8 Image Processor helps produce high image quality and fast operation, even in low light. When using high ISO settings, the image processor helps keep results sharp and detailed in virtually any lighting situation. Powerful all around, the DIGIC 8 Image Processor helps ensure your photos and videos look sharp and lifelike with minimal noise or grain.
4K Video, 4K Time-lapse Movie^
Capture 4K videos at a frame rate of up to 24p for high definition, cinematic results. Recording at almost four times the resolution of Full HD, you can see your subject in stunning clarity. Beautiful time-lapse videos can also be created in 4K simply and easily with the dedicated Time-lapse Movie mode. All of this is possible in-camera without the need for additional software.
^ Saving a still image from a single movie frame may not result in the same image quality as a normal still image.
Vertical Video Support*
Enjoy creating videos in the vertical position* and sharing to your preferred social media network with the EOS M200 camera’s Vertical Video feature. Great for the vlogger guru, the vertical video support allows you to mix up your shot length and camera angles to make your videos interesting, and unique.
The EOS M200 camera features a high-resolution, 3.0-inch Touch Panel LCD screen that tilts up 180° and down 45°, great for taking that picture-perfect selfie at high and low angles with ease. The multi-angle LCD screen encourages creative framing because it's easy to achieve a flexible array of camera angles.
Built-in Bluetooth®** Technology
Bluetooth®** pairing helps you connect the camera to compatible smart devices using the free Canon Camera Connect app*. This low-energy wireless connection helps preserve battery life while allowing remote control of the EOS M200 camera. It also sends continuously updated GPS^ location data from your phone, letting you geotag what you've captured so you can know precisely where you took that stunning vacation photo.
Built-in Wi-Fi®*** Technology
The EOS M200 camera is designed to make using Wi-Fi®*** connectivity fast and easy. It can transfer files directly to a compatible smart device using the free Canon Camera Connect app. Simply connect to the Camera Connect app* to transfer images to your smart device, then share and upload from the device directly to various social media sites and web services or print directly to compatible wireless Canon printers.
Images and effects are simulated.
Remote Shooting
Wireless capabilities also allow you to use your compatible smart devices with the Canon Camera Connect app* to remotely control the camera, which is useful for selfies and group shots or for shooting from a distance (as long as the camera is in wireless range).
Automatic Image Transfer^^
Backing up your photos and videos is easy with the EOS M200 camera, which can automatically send what you've captured to your computer and other compatible devices. After the initial setup with Image Transfer Utility 2, all you need to do is leave your camera on when it's connected to a Wi-Fi® network and the files will be sent without any further effort from you.
^ In certain countries and regions, the use of GPS may be restricted. Therefore, be sure to use GPS in accordance with the laws and regulations of your country or region. Be particularly careful when traveling outside your home country. As a signal is received from GPS satellites, take sufficient measures when using in locations where the use of electronics is regulated.
^^ It is necessary to download and install Canon's Image Transfer Utility 2. Connect the camera and computer each to your home network, and only the camera must be paired with ITU2 the first time.
Great for nighttime photography or in low light settings, the EOS M200 camera's AF can help capture sharp images. With a standard ISO sensitivity range of 100-25600 for stills and 100-12800 for video (100-6400 for 4K video & Time-lapse movie shooting), images can be captured with low noise and high detail.
Creative Assist
Making it simple to change camera settings and see the results in real time, the Canon EOS M200 camera’s built-in Creative Assist feature helps you find just the right look to match the emotion or tone of the image. With effects such as brightness, contrast and saturation easily found on one menu, the EOS M200 is a convenient camera to help you get great looks and experiment with different photography styles.
Feature Assistant
With its convenient Feature Assistant function, the EOS M200 camera can help you take advantage of its advanced features and create impressive photos with ease. By explaining and illustrating the camera's shooting modes and their effects with sample photos of each mode, the Feature Assistant encourages experimentation and provides guidance for creating amazing photographs.
Self Portrait Mode
With the help of the EOS M200 camera's Self Portrait mode, you can make adjustments ranging from smooth skin tones to background blurring and more. On top of that, you can enjoy recording videos or take a quick still image with a customizable self-timer — located directly on the LCD screen — to help make sure you capture the scenario that you want. Whether you need two seconds to flash a quick smile or ten seconds to gather your friends together, the EOS M200 camera is ideal for capturing a fun outing event.
Whether it's the bride saying "I do" or your newborn baby sleeping, the EOS M200 camera’s Silent Mode helps you make sure that your camera doesn't startle your subject by enabling capture with virtually no shutter sound. This means you can shoot precious moments without worrying about distracting them.
* Vertical Video Support is available for playback on the following compatible smart devices: iOS®; versions 9.3/10.3/11.2-11.4/12.2, Android™ smartphone and tablet versions 5.0/5.1/6.0/7.0/7.1/8.0/8.1/9.0.
** Compatible with iOS®; versions 9.3/10.3/11.2-11.4/12.2, Android™ smartphone and tablet versions 5.0/5.1/6.0/7.0/7.1/8.0/8.1/9.0. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain per-sonally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
*** Compatible with select smartphone and tablet devices (Android™ version 5.0 or later and the following iOS®; devices: iPhone 4s or later, iPad 3rd gen. or later, iPod Touch 5th gen. or later) equipped with Bluetooth®; version 4.1 or later and the Camera Connect App Ver. 2.5.20. This application is not guaranteed to operate on all listed de-vices, even if minimum requirements are met.
| Type | Digital Single-Lens Mirrorless AF/AE Camera | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Recording Medium | SD/SDHC/SDXC Memory Cards
Image Format |
| Compatible Lenses | Canon EF-M, EF* And EF-S* Lenses * Canon EF And EF-S Lenses Require Mount Adapter EF-EOS M. |
| Lens Mount | Canon EF-M Mount | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Type | CMOS Sensor (Supporting Dual Pixel CMOS AF) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Pixels | Effective Pixels: Approx. 24.1 Megapixels Total Pixels: Approx. 25.8 Megapixels |
| Aspect Ratio | 3:2 (Horizontal:Vertical) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| File Numbering | Continuous, Auto Reset File Format Data Type Recording Pixels Folder Setting Image Processing During ShootingPicture Style
White Balance
*1 Effective Also In Twilight And Sunset. Noise Reduction
Automatic Image Brightness Correction Highlight Tone Priority Lens Aberration Correction
Creative Assist
Creative Assist During Playback (RAW Or C-RAW Images):
| Type | Dual Pixel CMOS AF (1-Point AF, Spot AF, Face+Tracking Priority AF, Zone AF) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Af Points | Up To 143 Points (Maximum) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Af Working Range | EV -4-18 (At Center AF Point, Room Temperature, ISO 100, F/1.4, In One-Shot AF) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Af Assist Beam | Built-In LED Lamp | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Metering Modes | Real-Time Metering Using The Image Sensor Evaluative Metering Partial Metering (Approx. 5.8% Of Screen) Spot Metering (Approx. 2.9% Of Screen) Center-Weighted Average |
| Metering Range | Stills: EV -1-20 (At Room Temperature 73&Deg;F/23&Deg;C, ISO 100) Video: EV 0-20 (At Room Temperature 73&Deg;F/23&Deg;C, ISO 100) |
| Exposure Control Systems | Via SHOOTING MODE In Menu: • Program AE, Shutter-Priority AE, Aperture-Priority AE, Or Manual (B Is Selected As Shutter Speed Setting In Manual Mode) |
| Iso Speed Range | Stills: ISO 100-25600 (In 1/3-Stop Increments) Video: ISO 100-12800; H: 25600 |
| Exposure Compensation | Manual: &Plusmn;3 Stops In 1/3-Stop Increments | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Ae Lock | Manual, Auto (Exposure Locked After Focusing, In One-Shot AF With Evaluative Metering) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Type | Vertical-Travel Mechanical Focal-Plane Shutter, Electronically Controlled At All Speeds | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Shutter Speeds | Creative Zone: 1/4000 To 30 Sec., Bulb *X-Sync At 1/200 Sec. Basic Zone: 1/4000 To 1 Sec. |
| Self Timer | Off, 2-Second Self-Timer, 10-Second Self-Timer, Continuous Timer | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Type | Manual Pop-Up Flash (Max. Guide Number Approx. 16.4 [Ft] / 5.0 [M], At ISO 100) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Flash Metering System | E-TTL II Autoflash (Evaluative, Average), FE Lock | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Fe Lock | Provided | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Flash Exposure Compensation | &Plusmn;2 Stops In 1/3-Stop Increments | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Flash Metering | E-TTL II Autoflash (Evaluative, Average), FE Lock | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| External Flash Settings | Not Supported | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Continuous Shooting Speed |
*1 Conditions For Maximum Continuous Shooting Speed Are As Follows: Fully Charged Battery Pack LP-E12, Shutter Speed: 1/1000 Sec. Or Faster, Maximum Aperture (F/3.5), Room Temperature (73&Deg;F/23&Deg;C), 12 Bit *2 BR-E1: Supported / RC-6: Not Supported |
| Max Burst During Continuous Shooting |
*1 The Number Of Possible Shots And Maximum Burst Apply To A 32GB Card Based On Canon Testing Standards. |
| Grid Display | Off / 3x3 / 6x4 / 3x3+Diag Aspect Ratio Settings Focus Mode Continuous AF Touch Shutter Depth Of Field Preview |
| File Format | Video: MPEG-4 AVC / H.264 • Variable (Averaged) Bit Rate Audio: AAC |
| File Size | Recording Sizes: 4K (3840 X 2160): 23.98 Fps (Time Laps Only &Mdash; 29.97 Fps) Full HD (1920 X 1080): 59.94 Fps / 29.97 Fps HD (1280 X 720): 59.94 Fps (Hybrid Auto &Mdash; 29.97 Fps; High Frame Rate Movies &Mdash; 119.88 Fps) Recording System Movie Exposure Modes Metering Mode Exposure Compensation ISO Speed (Recommended Exposure Index) Miniature Effect Movie Still Image Shooting |
| Continuous Shooting Time |
* Limitations Of Video Shooting: Continuous Shooting Is Possible Until The Memory Card Becomes Full Or The Recording Length For One Video Reaches Approx. 29 Minutes And 59 Seconds (Or 7 Min. 29 Sec. For A HD High Frame Rate Movie). Sound Recording Card Performance Requirements
| Exposure Compensation | &Plusmn;3 Stops In 1/3-Stop Increments | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Type | TFT Color, Liquid-Crystal Monitor | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Screen Monitor Size | 3.0-Inch Type | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Pixels | Approx. 1.04 Million Dots | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Brightness Control | Manually Adjustable To One Of Seven Brightness Levels | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Interface Languages | 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukrainian, Turkish, Arabic, Thai, Simplified Chinese, Traditional Chinese, Korean, Malay, Vietnamese, Indonesian, Hindi, Japanese) Angle Adjustment Hints & Tips |
| Image Display Format | • Single Image, Or 4, 9, 36, Or 100-Image Index • Viewing Options Via INFO Button: Full Image, Full Image With Basic Info, Thumbnail Image With Histogram And Detailed Shooting Info, RGB And Brightness Histograms With Lens Info Playback Methods
Zoom Magnification Image Browsing Methods
Image Rotate Rating Video Playback Playback Time Slideshow
Post-Processing Of ImagesCreative Filters
Cropping Resize Red-Eye Reduction |
| Compatible Printers | PictBridge | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Printable Images | • JPEG • RAW / C-RAW |
| Custom Functions | 6 Available | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Custom Controls | Shutter Button, Movie Button InterfaceDigital Terminal HDMI OUT Terminal
Wireless Remote Control
| Battery | Battery Pack LP-E12 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Battery Life | Number Of Still Image Shots CIPA Compliant, Room Temperature 73&Deg;F/23&Deg;C: Approx. 315 Shots Eco Mode On: Approx. 485 Shots Movie Recording Time CIPA Compliant, Room Temperature 73&Deg;F/23&Deg;C: Approx. 90 Min. Continuous Shooting*: Approx. 135 Min. * Total Shooting Time When Shooting Is Performed Under The Following Conditions: Using Default AUTO Mode, Without Using Zooming And Other Operations, When Max. Recording Time Per Movie Is Reached And Recording Stops/Resumes Automatically. |
| Dimensions W X H X D | Approx. 4.3 X 2.6 X 1.4 In. (108.2 X 67.1 X 35.1mm) • CIPA Compliant. |
| Weight | Approx. 10.55 Oz. / 299g (Including Battery Pack And Memory Card) Approx. 9.24 Oz. / 262g (Body Only) |
| Operating Temperature Range | 32-104&Deg;F / 0-40&Deg;C | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Operating Humidity Range | 85% Or Less | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
HTC-100
Mini-HDMI Cable: connects Canon HD Camcorders/select PowerShot Cameras to HDMI compatible TV.
Interface Cable IFC-600PCU
Conveniently charge the battery in your PowerShot by connecting the camera to your computer using the IFC-600PCU cable
AC Adapter Kit ACK-E12
Allows the camera to be powered from a standard AC outlet. The kit includes CA-PS700 Compact Power Adapter and DR-E12 DC Coupler.
Compact Power Adapter CA-PS700A
This compact adapter powers your camera from an AC power supply and charges your batteries on the camera. This allows for uninterrupted recording of your special events and keeps your batteries ready to go.
DC Coupler DR-E12
Used in conjunction with a compatible AC adapter (not included) allows you to power your Canon EOS M directly from an AC Power source.
Allows Canon EF and EF-S lenses to be mounted on the Canon EOS M digital camera. Fully compatible with all lens functions including image stabilization and autofocus. Detachable tripod adapter provides support for longer Canon lenses.
Wall battery charger compatible with battery pack LP-E12.
Battery Pack LP-E12
Battery pack for EOS M allows up to 1hr 30 min. of movie shooting time and approximately 230 shots (at 73°F/23°C).
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
