EOS 90D
- EOS 90D Body
- Battery Pack LP-E6N
- Battery Charger LC-E6
- Neck Strap
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Fast. Versatile. Impressive. Whether capturing high-speed sporting events or simple, everyday moments, the EOS 90D camera is engineered to deliver impressive results. Equipped with an enhanced 32.5 Megapixel CMOS (APS-C) sensor, powerful DIGIC 8 image processor and an ISO range of 100-25000 (expandable to 51200), you’ll achieve sharp, detailed images, even in low-light settings. Perfect for fast-moving subjects, the EOS 90D camera features a 45-point cross-type AF system* and EOS iTR AF (face detection) — plus high-speed continuous shooting of up to 10 fps — raising the game for wildlife and motor sports photography enthusiasts. And with stunning uncropped 4K 30p video capability, the EOS 90D documents your travels, events and other milestones in full, wide-angle view. No matter where your photography ventures take you, the EOS 90D proves to be the versatile, all-around SLR camera you didn’t know you were missing.
The Canon EOS 90D camera features a powerful 32.5 Megapixel CMOS (APS-C) sensor that can capture high-resolution images. Utilizing a sophisticated light-capturing design, it provides high sensitivity for high ISO capture with reduced noise, delivering clear, detailed results even in low light. It also enables fast continuous shooting and fast autofocus for high-speed performance that helps you capture once-in-a-life time moment.
DIGIC 8 Image ProcessorThe DIGIC 8 Image Processor helps produce high image quality and fast operation, even in in low light. When using high ISO settings, the image processor helps keep results sharp and detailed in virtually any lighting situation. Powerful all around, the DIGIC 8 Image Processor helps ensure your photos and videos look sharp and lifelike with minimal noise or grain.
With a new, rugged shutter designed for 120,000 cycles, the EOS 90D camera can shoot up to 10 frames per second during viewfinder shooting, and approx. 11fps during live view shooting to capture all the action. With super quick AF and exposure systems complementing the shutter's 55m sec shutter release time lag, the EOS 90D camera is tailored to meet and even exceed the speed of the action with no time lag while shooting through the optical viewfinder.
Thanks to the DIGIC 8 image processor, and APS-C size CMOS image sensor, enjoy recording uncropped 4K videos at up to 30 frames per second. Recording at almost four times the resolution of Full HD, you can see your subject in stunning clarity.
FHD 120fps VideoFull HD videos at up to 120 frames per second can also be recorded using the EOS 90D camera - delivering refined and detailed image quality. Designed to capture fun, beautiful videos, the EOS 90D camera helps ensure that you can see the unique expressions of your friends' or family's faces in close-up movies.
The EOS 90D camera has a wide-area, 45-point, all cross-type AF system* that helps you get what you want in focus, quickly. This comes in especially handy when trying to photograph fast-moving subjects, like athletes racing at a motocross event, or an athlete scoring a goal. The EOS 90D is compatible with most EF and EF-S lenses that has a maximum aperture of f/8 or higher, and some lenses with extenders attached may operate at a maximum of 27 points. With minimal glare and minimal lag time while looking through the optical viewfinder, the EOS 90D camera will help you get the shot you want without having to lose the fast-moving subject - even in unpredictable settings.
The EOS 90D camera is equipped with an advanced 220,000-pixel AE sensor and DIGIC 8 image processor, that greatly contribute to the camera's impressive AF performance for both stills and video. The EOS 90D camera also incorporates Canon’s EOS Intelligent Tracking and Recognition system (EOS iTR AF) that detects and tracks your face - even while looking through the optical viewfinder - automatically switching the AF point to optimize face tracking. Using tracking algorithms tailored to recognize faces and colors, this system not only helps to quickly and automatically select the ideal capture settings, but also serves as a brilliant foundation to the EOS 90D AF system.
The EOS 90D camera lets you shoot with Dual Pixel CMOS AF for fast, accurate autofocus that helps you get the photo you want right as the moment happens. This means fast action can be captured and focus can be maintained with speed, accuracy and ease.
AF Area Coverage of Approx. 88% x 100%^
The EOS 90D camera features an expansive focus area of approx. 88% horizontal and 100% vertical^ when working with select EF and EF-S lenses. With older EF lenses, or with Extender types I and II, the EOS 90D camera focuses approx. 80% horizontally and 80% vertically. This means fast and impressive focusing even if your subject is way off center.
^ When shooting still photos. Actual coverage varies depending on the lens in use.
AF Points and AF AreaFeaturing a sophisticated AF system with a maximum of 5,481 manually selectable AF points**, the EOS 90D can be configured to focus on a specific area during live view shooting, using an extended range of selectable modes that include Face + Tracking AF, single-point Spot AF (ideal for subjects such as animals), zone AF, and single-spot AF.
>Designed to allow users to operate customizable camera functions while looking through the optical viewfinder, the EOS 90D camera features two multi-controller buttons located on the back of the camera that makes it easy for the user to locate and control.
Battery Grip BG-E22
The EOS 90D camera's dedicated Battery Grip BG-E14 holds 2 Battery Packs LP-E6N, while enabling virtually seamless vertical operation and additional functions with all buttons similarly configured in a comfortable and dedicated grip. Designed to maintain an optimal balance between the weight of the camera body and lens, the Battery Grip BG-E14 also adds a flash sync terminal for use in the studio. It also has a useful battery charging function (with optional USB power delivery adapter attached) that's particularly helpful for power-hungry operations like video recording or shooting over an extended period of time with the OVF.
The EOS 90D camera features a powerful electronic shutter system with speeds from 1/16000 second during live view shooting and a mechanical/electronic 1st-curtain shutter with a maximum of 1/8000 second. Not only is this effective at preventing camera shake, but the EOS 90D camera can help capture fast-speed moments such as motocross events, in sharp detail.
The EOS 90D camera features a 3.0-inch Vari-angle Touch Screen LCD that can be ideal for composing and reviewing your photos. Tap the screen during Live View while taking photos or videos and thanks to Dual Pixel CMOS AF, the EOS 90D camera will quickly lock focus to that specific location in the image. Touch gestures can be used for zooming in or swiping through images after you've taken them. In addition, the Vari-angle Touch Screen LCD lets users capture high-quality selfie shots with ease.
The EOS 90D camera is designed to make connecting to a Wi-Fi®*** network fast and easy. It can exchange data with other Wi-Fi® connected compatible Canon cameras, and transfer files directly to a compatible smart device using the Camera Connect app. The Wi-Fi® capability lets you share and upload directly to various web services like CANON iMAGE GATEWAY^, Facebook® and YouTube® as well as print directly to compatible wireless Canon printers.
Built-in Bluetooth®**** CapabilityBluetooth®**** pairing helps you connect the camera to compatible smart devices using the free Canon Camera Connect app*. To customize the Bluetooth® function, simply click on the network icon located on the LCD screen. In addition, Bluetooth® lets you connect to the optional Wireless Remote Control BR-E1 for remote shooting as well as pick up GPS shooting location data from the user’s compatible smartphone while using the GPS receiver GP-E2.
^ One-time registration is required on CANON iMAGE GATEWAY online photo album.
Canon's Digital Photo Professional Express makes speedy processing of JPEGs and CR3 RAW files on a compatible handheld device a breeze. Working with Canon's Camera Connect app^^^ to create a streamlined wireless workflow, DPP Express lets you adjust settings right on your mobile device, saving files to the cloud, a PC or your camera.
^^^ Compatible with iOS® versions 10.3/11.2-11.4/12.2, Android™ smartphone and tablet versions 4.4/5.0/5.1/6.0/7.0/7.1/8.0/8.1/9.0. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
* The number of AF points, cross-type AF points and Dual cross-type AF points vary depending on the lens used.
** Available AF points may decrease when shooting with AF cropping or in movie mode, or depending on camera settings or lens attached.
*** Compatible with iOS®; versions 9.3/10.3/11.2-11.4/12.2, Android™ smartphone and tablet versions 5.0/5.1/6.0/7.0/7.1/8.0/8.1/9.0. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
**** Compatible with select smartphone and tablet devices (Android™ version 5.0 or later and the following iOS®; devices: iPhone 4s or later, iPad 3rd gen. or later, iPod Touch 5th gen. or later) equipped with Bluetooth®; version 4.1 or later and the Camera Connect App Ver. 2.5.10. This application is not guaranteed to operate on all listed devices, even if minimum requirements are met.
| Type | Digital, AF/AE Single-Lens Reflex Camera With Built-In Flash | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Recording Medium | SD, SDHC And SDXC Memory Cards SD Speed Class Compatibility. UHS Speed Class Compatibility. High-Speed Writing Is Supported When A UHS-I Or UHS-II-Compatible SD Card Is Used. Multimedia Cards (MMC) Cannot Be Used (Card Error Will Be Displayed). |
| Image Format | Approx. 22.3mm X 14.8 Mm (APS-C) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Compatible Lenses | Canon EF Lenses (Including EF-S Lenses, Excluding EF-M Lenses) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Lens Mount | Canon EF Mount | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Type | CMOS Sensor | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Pixels | Approx. 32.5 Megapixels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Pixel Unit | Approx. 3.2 Μm Square | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Total Pixels | Approx. 34.4 Megapixels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Aspect Ratio | 3:2 (Horizontal: Vertical) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Color Filter System | RGB Primary Color Filters | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Low Pass Filter | Fixed Position In Front Of The Image Sensor | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Dust Deletion Feature | (1) Self Cleaning Sensor Unit
| Recording Format | Design Rule For Camera File System 2.0 And EXIF 2.31* * Supports Time Difference Information. |
| Image Format | Still Image: JPEG, RAW (14 Bit Canon Original), C-RAW Video: MP4 (Movie: MPEG4 AVC/H.264*; Audio: AAC Audio: Linear PCM) * Variable (Averaged) Bit Rate |
| File Size | 3:2 Aspect Ratio Large: Approx. 32.3 Megapixels (6960 X 4640) Medium: Approx.15.4 Megapixels (4800 X 3200) Small 1: Approx. 8.1 Megapixels (3472 X 2320) Small 2: Approx. 3.8 Megapixels (2400 X 1600) RAW / C-RAW: Approx. 32.3 Megapixels (6960 X 4640) 4:3 Aspect Ratio Large: Approx. 28.6 Megapixels (6160 X4640) Medium: Approx. 13.6 Megapixels (4256 X 3200 Small 1: Approx. 7.1 Megapixels (3072 X 2320) Small 2: Approx. 3.4 Megapixels (2112 X 1600) RAW / C-RAW: Approx. 32.3 Megapixels (6960 X 4640) 16:9 Aspect Ratio Large: Approx. 27.2 Megapixels (6960 X 3904) Medium: Approx. 12.9 Megapixels (4800 X 2688) Small 1: Approx. 6.8 Megapixels (3472 X 1952) Small 2: Approx. 3.2 Megapixels (2400 X 1344) RAW / C-RAW: Approx. 32.3 Megapixels (6960 X 4640) 1:1 Aspect Ratio Large: Approx. 21.5 Megapixels (4640 X 4640) Medium: Approx. 10.2 Megapixels (3200 X 3200) Small 1: Approx. 5.4 Megapixels (2320 X 2320) Small 2: Approx. 2.6 Megapixels (1600 X 1600) RAW / C-RAW: Approx. 32.3 Megapixels (6960 X 4640) Values Of Pixels Recorded Are Rounded Off To The Nearest 100,000th. JPEG Images Are Generated In The Aspect Ratio That Was Set. RAW/C-RAW Images Are Generated In [3:2] And The Set Aspect Ratio Is Appended. |
| File Numbering | The Following Three Types Of File Numbers Can Be Set:
| Color Space | SRGB, Adobe RGB | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Picture Style |
| Settings | Auto, Daylight, Shade, Cloudy*, Tungsten Light, White Fluorescent Light, Flash, Custom, Color Temperature Setting * Effective In Twilight And Sunset As Well. |
| Auto White Balance | Option Between Ambience Priority And White Priority Settings | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Color Temperature Compensation | Blue/Amber Bias: ±9 Levels Magenta/Green Bias: ±9 Levels Corrected In Reference To The Current WB Mode's Color Temperature. |
| Color Temperature Information Transmission | Provided | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Type | Eye-Level SLR (With Fixed Pentaprism) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Coverage |
| Magnification | Approx. 0.95x (With 50mm Lens At Infinity, -1m-1) / 28.2° Angle Of View | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Eyepoint | Approx. 22mm (At -1m-1 From Eyepiece Lens Center) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Dioptric Adjustment Correction | Adjustable From Approx. -3.0 To +1.0 M-1 (Dpt) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Focusing Screen | Fixed | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Viewfinder Information | Information Display On A Transparent LCD Screen
Mirror Lockup |
| Depth Of Field Preview | Provided | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Type | TTL Secondary Image-Forming Phase-Difference Detection System With AF-Dedicated Sensor | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Af Points | Up To 45 Points (Cross-Type AF Points: Max. 45)
Note That, With Aspect Ratio Of 1:1, The Maximum Number Of AF Points Becomes 35. (Each Left And Right End Line Of AF Points In Total Of Ten Are Not Usable.) |
| Af Working Range | One-Shot AF, Room Temperature, ISO 100 (Based On Canon’s Testing Standards And Environment)
| Focusing Modes |
Select AF Area Selection Mode
Orientation Linked AF Point AF Microadjustment Automatic AF Point Selection: EOS ITR AF
* Applied When The AF Are Selection Modes Are Zone AF, Large Zone AF, Or Auto Selection AF. |
| Af Assist Beam | Intermittent Firing Of Built-In Flash Effective Range: Center: Approx. 13.1 Ft. / 4.0m Periphery: Approx. 13.1 Ft. / 4.0m With An EOS-Dedicated Speedlite Attached, The Speedlite’s AF-Assist Beam Is Emitted Instead. Focusing Method Focusing Operation
* Dual Pixel CMOS Af Is Supported With All EF And EF-S Lenses. |
| Metering Modes | 216-Zone (18 X 12) Metering With Approx. 220,000-Pixel RGB+IR Metering Sensor And TTL Full-Aperture. 384-Zone (24 X 16) Metering Using Image Sensor Output Signals (Live View And Movie Recording). The Following Metering Modes Selectable: (1) Evaluative Metering (Linked To All AF Points) (2) Partial Metering On The Center Part Of The Viewfinder (Approx. 6.5% Of Viewfinder/Approx. 4.5% In Live View) (3) Spot Metering (Approx. 2.0% Of Viewfinder/Approx. 2.6% In Live View) (4) Center-Weighted Average Metering |
| Metering Range | OVF: EV 1-20 (Room Temperature, ISO 100, With Evaluative Metering) Live View: EV -2-20 Movie Recording: EV 0-20 |
| Exposure Control Systems | Creative Zone
Basic Zone
| Iso Speed Range | Manual Setting
For [Highlight Tone Priority], The Settable ISO Speed Range Will Be ISO 200-25600. Auto Setting
*1 ISO 200 When [Highlight Tone Priority] Is Set To [Enable] Or [Enhanced]. Anti-Flicker Shooting |
| Exposure Compensation | Manual: ±5 Stops In 1/3- Or 1/2-Stop Increments AEB: ±3 Stops In 1/3- Or 1/2-Stop Increments * Indicated Up To ±3 Stops On The LCD Panel And In The Viewfinder. |
| Ae Lock |
Shooting In HDR Mode (Still Photos)Adjust Dynamic Range Effect Continuous HDR Auto Image Align |
| Type | Vertical-Travel, Mechanical, Focal-Plane Shutter With All Speeds Electronically-Controlled | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Shutter Speeds | Creative Zone: 1/16000 To 30 Sec., Bulb (Total Shutter Speed Range) * 1/16000 Is Only When Electric Shutter Mode Is Selected. Basic Zone: 1/8000-1sec X-Sync At 1/250 Sec. |
| Shutter Release | Soft-Touch Electromagnetic Release | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Self Timer | 10-Sec. Delay, 2-Sec. Delay, Continuous Timer ShootingBulb Timer
Interval Timer |
| Type | Retractable Flash In The Pentaprism Housing Retraction Method |
| Guide Number | Approx. 39.4 Ft./12m (At ISO 100) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Flash Coverage | Up To Approx. 17mm Focal Length (35mm Equivalent: Approx. 28mm) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Flash Exposure Compensation | Up To ±3 Stops In 1/3- Or 1/2-Stop Increments Flash Exposure Compensation For Built-In Flash And External Speedlite Can Be Set With The Camera. Multiple Exposure ShootingMultiple-Exposure Shooting Multiple-Exposure Control No. Of Exposures Continue Multiple Exposures Saving Source Images |
| Flash Exposure Compensation | Up To ±3 Stops In 1/3- Or 1/2-Stop Increments Flash Exposure Compensation For Built-In Flash And External Speedlite Can Be Set With The Camera. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| External Flash Settings |
| Drive Modes |
| Continuous Shooting Speed | Drive Mode And Continuous Shooting Speed:
*1 Maximum Continuous Shooting Speed With Flicker Reduction May Drop To Approx. 7 Shots/Sec. Image File Size/Number Of Possible Shots/Maximum Burst During Continuous Shooting:
*1 The Number Of Possible Shots And Maximum Burst Apply To A UHS-I Compliant 32GB Card Based On Canon’s Test Standards. |
| Shooting Modes | Still Photo And Video Recording | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Focusing |
* AE Lock Possible. The Active Metering Timer Can Be Changed. |
| Metering Modes |
| Metering Range | EV 0-20 (Room Temperature, ISO 100, With Evaluative Metering) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Grid Display |
| Exposure Simulation | Possible | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Silent Shooting | Provided (Mode 1 And Mode 2) Image Processing After ShootingIn-Camera RAW Image Processing |
| File Format | MP4: Movie: MPEG-4 AVC/H.264 * Variable (Average) Bit Rate Audio: AAC 4K Movie Recording Time-Lapse Movie Video Snapshots Creative Filters (Movie)
* Magnified View Is Not Available In Live View Shooting. HDR Movie
High Frame Rate Movies
* Movie Recording Is Interrupted If The Maximum Recording Time Per Movie, 7 Min. 29 Sec., Is Exceeded. High Frame Rate Movies
HDMI Output
• Content In The Output Format Set On The Camera Is Displayed On The Device Connected Via HDMI. |
| File Size | MP4:
| Frame Rates | MP4: 1920 X 1080 (Full HD): 60 Fps (59.94 Fps) / 30 Fps (29.97 Fps) 1280 X 720 (HD): 60 Fps (59.94 Fps) / 30 Fps (29.97 Fps) |
| Continuous Shooting Time | MP4 Format
* Bit Rate Indicates Video Output Only, Audio Is Not Included. |
| Focusing |
| Exposure Compensation | ±Stops In 1/3- Or 1/2-Stop Increments * Likewise ±3 Stops For Still Photo Shooting. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Type | TFT Color, Liquid-Crystal Monitor Touch Screen |
| Screen Monitor Size | Wide 3.0-Inch (Screen Aspect Ratio Of 3:2) Approx. 3.0 In. Diagonal (Approx. 2.5 In. Wide, Approx. 1.7 In. High) |
| Pixels | Approx. 1.04 Million Dots | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Coverage | Approx. 100% Viewing Angle: Approx. 170° Vertically And Horizontally |
| Brightness Control | Adjustable To One Of Seven Levels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Coating | Anti-Smudge Coating | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Interface Languages | 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, And Japanese) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| On Lcd Monitor | Single Image Display:
Index Display:
| Highlight Alert | With Single Image Display, Overexposed Highlight Areas Will Blink. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Histogram | Brightness And RGB Rating Image Search Slide Show
Quick Control FunctionShortcut |
| Protection | Erase Protection Can Be Applied Or Canceled For A Single Image, All Images In A Folder Or All Images In The Card. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Erase | Erase A Single Image, Selected Images, All Images In A Folder Or All Images In A Card. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Compatible Printers | PictBridge-Compatible Printers (Wireless LAN) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Printable Images | JPEG Images Compliant To Design Rule For Camera File System. RAW Images Captured Movies Cannot Be Printed. |
| Dpof | Compliant To DPOF Version 1.1 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Compatible Images | Not Provided | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Custom Functions | 29 Custom Functions Are Settable. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Custom Controls | Functions Can Be Assigned To The Following Buttons:
| My Menu Registration | Up To Six Top-Tier Menu Options And Custom Function Settings Can Be Registered. Up To Five My Menu Tabs Can Be Added. |
| Usb Terminal | Hi-Speed USB (USB 2.0)
Terminal Type |
| Video Out Terminal | HDMI Type C (Resolution Switches Automatically), CEC Not Supported. • Video Is Not Displayed Unless The Video Format Appropriate For The Connected TV Set, [NTSC] Or [PAL], Is Set. |
| Battery | Battery Pack LP-E6N (Or LP-E6) X 1 • When The Battery Grip Is Used, Two Battery Packs (LP-E6N Or LP-E6) Can Be Installed. Also Usable With Six AA/R6 Batteries. |
| Battery Check | Automatic Battery Check When The Power Switch Is Turned ON. Displayed In 6 Levels. • Battery Level Displayed On LCD Panel And In Viewfinder. • Displayed In Four Levels With The Battery Grip With AA/R6 Batteries. |
| Power Saving | Power Turns Off After The Set Time (10/30*Sec., Or 30 Sec., 1, 2, 4, 8, Or 15min.) Of Non-Operation Elapses. * Set To 10 Sec. Normally And 30 Sec. When Setting Functions, In Live View Shooting And During Image Playback. |
| Date Time Battery | Built-In Secondary Battery Maintains Date/Time For About 3 Months When Fully Charged
| Start Up Time | Approx. 0.2 Sec. (Based On CIPA Testing Standards) • Excluding The Recognition Time For Genuineness (Genuine Canon Battery) At The Installation Of The Battery. |
| Dimensions W X H X D | Approx. 5.54 X 4.13 X 3.03 In. / 140.7 X 104.8 X 76.8mm | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Weight | Approx. 24.73 Oz. / 701g (Based On CIPA Guidelines) Approx. 21.83 Oz. / 619g (Body Only; Excluding The Battery, Card, Body Cap And Eye Cup) |
| Operating Temperature Range | 32-104°F/0-40°C | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Operating Humidity Range | 85% Or Less | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Timer Remote Controller TC-80N3
Remote switch for EOS cameras with the N3-type socket. This remote switch has a self-timer, interval timer, long exposure timer and exposure-count setting feature. The timer can be set from 1 second to 99 hours. A new dial enables you to easily enter the numeric settings with a single thumb. It has an illuminated LCD panel and a 2.6ft/80cm cord.
Remote Controller Adapter RA-E3
Directional Microphone
DM-E1
Crisp sound. Superb performance. The new Directional Microphone DM-E1 can help experienced videographers and aspiring filmmakers alike achieve high-quality audio when recording video using a compatible Canon EOS digital camera*.
A wireless remote controller compatible with Bluetooth enabled cameras for wireless focusing, still shooting and video recording, and zooming using the Power Zoom Adapter PZ-E1. Operating distance is approximately 16 ft in any direction.
Protecting Cloth PC-E1
The Protecting Cloth is for the purpose of protecting equipment such as a camera and lens from dirt and scratches, etc., but it cannot protect equipment from shocks or pressure.
Protecting Cloth PC-E2
The Protecting Cloth is for protecting equipment such as a camera and lens from dirt and scratches, etc.; it cannot protect equipment from shocks or pressure. Suitable for smaller camera as it is smaller than the Protecting Cloth PC-E1.
AC Adapter Kit ACK-E6
Provides AC power to the camera.
Battery Charger for NP-E6 Li-ion Batteries.
DC Coupler DR-E6
When shooting indoors, in a studio or on a tabletop, use this DC coupler to provide uninterrupted power to your Canon Digital SLR.
AC Adapter AC-E6N
Provides AC power to the camera with the combination of DR-E6.
Battery Grip BG-E14
This large capacity battery grip is powered by two Battery Pack LP-E6, six AA-size/LR6 batteries or an optional AC Adapter Kit ACK-E6. It features a variety of operating controls such as shutter button, Main Dial,, AF point selection button, AE lock/FE lock button, AF point selection button, and AF start button. This is ideal for high volume and easy vertical shooting.
Battery Pack LP-E6N
Rechargeable lithium-ion battery. Compatible with Canon LC-E6 and Canon LC-E6E battery chargers.
Rubber Frame Eb
Magnifier MG-Eb
A viewfinder accessory developed to make it easier to check the composition. It magnifies the viewfinder image by approx. 1.2 times.
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
