EOS 5D Mark IV
- EOS 5D Mark IV Body
- Battery Pack LP-E6N
- Battery Charger LP-E6
- Eyecup Eg (Not shown)
- Wide Strap
- Cable Protector
- Interface Cable IFC-150U II
- EOS DIGITAL Solution Disk (Not shown)
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
See Legendary.
The EOS 5D Mark IV camera builds on the powerful legacy of the 5D series, offering amazing refinements in image quality, performance and versatility. Canon's commitment to imaging excellence is the soul of the EOS 5D Mark IV. Wedding and portrait photographers, nature and landscape shooters, as well as creative videographers will appreciate the brilliance and power that the EOS 5D Mark IV delivers. Superb image quality is achieved with Canon's all-new 30.4 Megapixel full-frame sensor, and highly-detailed 4K video is captured with ease. Focus accuracy has been improved with a refined 61-point AF system and Canon's revolutionary Dual Pixel CMOS AF for quick, smooth AF for both video and Live View shooting. Fast operation is enhanced with Canon's DIGIC 6+ Image Processor, which provides continuous shooting at up to 7.0 fps*. Built-in Wi-Fi®**, GPS*** and an easy-to-navigate touch-panel LCD allow the camera to become an extension of you. When quality matters, the EOS 5D Mark IV helps deliver results to inspire even the most discerning imagemaker.
The EOS 5D Mark IV camera boasts a full-frame, high-speed CMOS sensor that’s ideal for a broad range of applications with its remarkable high-resolution abilities. Measuring approximately 36.0mm x 24.0mm, the same size and ratio as a 35mm film frame, it records 30.4 effective Megapixels at normal ISOs of up to 32000. It also captures incredible still and 4K video clips suitable for significant post-processing, retouching and cropping. Versatile in virtually all kinds of light and any shooting situation from print and wedding to full-bleed magazine spreads and other commercial or fine art use, the EOS 5D Mark IV consistently produces high-resolution 4K video and image files that are easily compatible with any number of diverse workflows.
ISO 10032000 (expandable to 50102400)
Featuring an ISO range of 10032000 (expandable to 50102400), the EOS 5D Mark IV camera is incredibly well-suited for low-light photography. Its sensor has an improved S/N ratio plus an improved noise-processing algorithm to help deliver high-level light sensitivity along with its high resolution, with virtually no compromise in image quality. Whether working in a dimly lit auditorium, trying to capture the action at night, photographing at the fastest possible shutter speed or simply suppressing camera shake blur, the EOS 5D Mark IV has an extended ISO range that contributes to its ability to excel in nearly every situation it faces.
The EOS 5D Mark IV is a remarkably capable video camera. Thanks to its impressive CMOS sensor and its high-speed DIGIC 6+ Image Processor, it can transition from taking still photographs to shooting videos in a near instant, capturing Digital Cinema (DCI) standard 4K (Motion JPEG) videos of 4096 x 2160 pixels at up to 30 or 24 fps*. Adding to its versatility, it also supports the 4K broadcasting standard of 3840 x 2160 pixels with slight trimming on the left and right sides. Featuring advanced Live View operation and brilliantly responsive Dual Pixel CMOS AF, the EOS 5D Mark IV has a touch panel display with focus points that can easily be selected during operation, and quickly confirmed by selecting and saving an 8.8-Megapixel image with in-camera 4K still frame grab**. Along with capturing beautiful 4K videos, the EOS 5D Mark IV is equally able to shoot Full HD video at up to 60p plus HD at frame rates as high as 120p, ideal for smooth slow-motion video. It also supports both MOV and MP4 formats for a variety of applications right out of the camera.
* 4K requires the following write speed requirements: CF UDMA7 (100MB/sec. or faster); SD UHS-I (90MB/sec. or higher)
** Saving a still image from a single movie frame may not result in the same image quality as a normal still image.
- Proper operation cannot be guaranteed for all recording media.
- Card compatibility based on Canon?s testing standards as of August 2016.
- We recommend users format the memory card in camera and conduct a test prior to actually shooting 4K video.
Adding to its powerful and portable design, the EOS 5D Mark IV camera utilizes Canon’s smooth, fast and intelligent Dual Pixel CMOS AF. Featuring two photodiodes per pixel and each pixel capable of phase-difference detection autofocus, the CMOS sensor can deliver fast and accurate AF throughout approximately 80% of the image plane. Able to detect shifts in movement at the pixel level, Dual Pixel CMOS AF enables continuous automatic AF and AF tracking that enhances overall camera operation for sharp still images and smooth, accurate focus transitions in movies. Working with the EOS 5D Mark IV’s 3.2" touch panel LCD screen, Dual Pixel CMOS AF lets photographers select focus points throughout the frame with the touch of a finger, and confirm focus by zooming in on the image or enlarging stills grabbed from video recordings.
The EOS 5D Mark IV camera features a 1.62 million dot, low-reflection 3.2-inch Clear View LCD II monitor for bright, sharp display in a wide variety of shooting situations. The LCD’s touch panel surface facilitates fast, intuitive operation, including AF frame switching, menu and setting changes plus image magnification during Live View shooting and movie shooting. Still photographs can also be captured quickly with the touch panel’s shutter release function. A customizable Quick Control screen adds flexibility and convenience for specific users’ preferences. Image review and playback are also enhanced with the EOS 5D Mark IV camera’s Clear View LCD II Monitor. Not only does the EOS 5D Mark IV’s LCD provide a high-precision image for composition and playback, but it also remains visible even when the photographer is wearing polarized sunglasses! In numerous situations in the studio and in the field, the EOS 5D Mark IV’s LCD panel is an ideal complement to its amazing TTL viewfinder.
The EOS 5D Mark IV camera is designed to keep up with the action. Its remarkable shutter, advanced AF and exposure and image processing systems help ensure virtually instantaneous response and performance at up to 7.0 fps**, even at full resolution. Whether searching for a joyous expression on a bride’s face or capturing an athlete in action, the EOS 5D Mark IV doesn’t let file size compromise the speed of capture even when bracketing exposures of a complex lighting situation, helping photographers and moviemakers attain consistently high performance in many situations.
** Continuous shooting speed may vary depending on the shutter speed, the aperture, the lens being used, the battery charge and various camera settings.
DIGIC 6+ Image ProcessorThe powerful DIGIC 6+ Image Processor increases the EOS 5D Mark IV camera’s in-camera capabilities, enabling fast operation across the board and helping to ensure that high-quality still image and 4K video recording is achieved no matter the shooting environment. It has a noise-processing algorithm that helps reduce noise at high ISO settings, and features a Digital Lens Optimizer that can automatically apply a variety of aberration and diffraction corrections as well as other corrective measures specific to the lens in use. The EOS 5D Mark IV’s power to perform numerous operations with ease is made possible in large part thanks to the amazing DIGIC 6+ Image Processor.
To complement its stellar CMOS sensor and powerful processing abilities, the EOS 5D Mark IV camera incorporates a 61-point High Density Reticular AF II system. It features up to 41 cross-type points and an extensive AF area that extends well into the top and bottom of the peripheral frame. It also has a wide subject tracking area that enhances the AF system with consistent focus tracking to capture the action at hand and includes Canon’s AI Servo AF III, which remembers the AF path and helps refine precision shot-to-shot. Low-light performance is phenomenal the AF system’s low-intensity limit is EV -3 at the center AF point and all 61 AF points are compatible down to f/8 for excellent low-light performance, even with lens extenders attached. To help ensure that AF points and other shooting information are visible at a glance, the EOS 5D Mark IV also features Canon’s Intelligent Viewfinder II for a bright, customizable view. Whether choosing individual AF points manually or using one of the camera’s automatic AF selection modes, the EOS 5D Mark IV’s AF system is a significant part of its overall excellence.
To help deliver nearly fool-proof performance, the EOS 5D Mark IV camera employs a powerful and instant subject and light analysis system. The iSA Intelligent Scene Analysis system uses its own RGB+IR light sensor with an approximately 150,000-pixel resolution to provide the camera with immense image analysis in an instant, making necessary corrections along the way. The sensor enables Canon’s anti-flicker function, which detects the frequency and phase of a light source’s flicker (such as a fluorescent light) and captures images near the point of peak brightness when the subject is most likely to be well-illuminated. The EOS 5D Mark IV also incorporates Canon’s Intelligent Tracking and Recognition system (iTR AF) that detects and tracks subjects, automatically switching the AF point to optimize tracking. Using tracking algorithms tailored to recognize faces and colors, this system not only helps to quickly and automatically select the ideal capture settings, but also serves as a brilliant foundation to the EOS 5D Mark IV’s AF system.
The EOS 5D Mark IV camera is equipped with a number of advanced features designed to combat image degradation from lens aberration, focus and other characteristics that can adversely affect the quality of the final image. The EOS 5D Mark IV’s Dual Pixel CMOS AF system enables capture of Dual Pixel Raw (DPRAW) files***. Images shot as DPRAWs have additional adjustment possibilities when processed with Canon’s Digital Photo Professional image processing software, which enables pixel-level adjustment and refinement for still photographs and includes Image Micro-adjustment to help maximize sharpness in detail areas, Bokeh Shift for more pleasing soft focus areas and Ghosting Reduction to help reduce aberrations and flare. The EOS 5D Mark IV camera is also equipped with a number of in-camera optical correction functions previously available only using Digital Photo Professional. It comes preloaded with aberration data particular to specific lenses, helping to eliminate the need to register lens data on previously released lenses and correcting images with virtually no delay in-camera. The EOS 5D Mark IV not only fixes peripheral brightness and chromatic aberration, but also features distortion correction and diffraction correction. Distortion correction helps resolve barrel and pincushion distortions, while diffraction correction helps to eliminate the blurring effects from diffraction that can be created when capturing an image at a small aperture. The EOS 5D Mark IV’s in-camera Digital Lens Optimizer works with the camera’s DIGIC 6+ Image Processor to help ensure these corrections can be made with virtually no effect on operational speed, even when shooting numerous successions of JPEG images, speeding up the photographer’s workflow and delivering gorgeous images right from the camera.
*** When lens diaphragm setting is fully open, adjustment volume and compensation effect are emphasized. Sufficient adjustment volume and compensation effect may not be achieved, depending on lens in use and shooting conditions. Adjustment volume and compensation effect vary depending on camera position (landscape or portrait).
For a useful and quick workflow in a variety of locations, the EOS 5D Mark IV camera’s built-in Wi-Fi®^ feature can help streamline camera operations across the board. Using the free Canon Camera Connect app^ on a compatible iOS® or Android™ device, the EOS 5D Mark IV can easily be set up to shoot remotely from a distance, even in Live View mode, with complete control of settings such as aperture, shutter speed, ISO, focus and shutter release. Image review and transfer are similarly fast and easy without ever having to take the camera out of its bag. Full DLNA (Digital Living Network Alliance) compatibility means easy sharing between the EOS 5D Mark IV and other DLNA products, such as HDTVs and compatible smartphones. Still images can even be transferred between two wireless-enabled Canon cameras over a Local Area Network (LAN). Images and video can also be uploaded instantly to CANON iMAGE GATEWAY# for easy sharing on social networking sites, and photos can even be printed on a wireless PictBridge-certified printer without the need for a PC. For more robust Wi-Fi® connections, the EOS 5D Mark IV is also compatible with Canon’s optional Wireless File Transmitter WFT-E7, which supports 2.4GHz/5GHz frequency bands, multiple camera sync and can extend the EOS 5D Mark IV’s operating range up to 10 times that of the camera’s built-in Wi-Fi®.
# One-time registration is required on CANON iMAGE GATEWAY online photo album.
Built-in NFC Technology
Built-in NFC (Near Field Communication) technology helps provide the EOS 5D Mark IV camera with a virtually seamless connection to compatible Android™ devices^^. Simply tap to connect and transfer images and videos. It’s also compatible with the Canon Connect Station CS100 device, which makes it simple for photographers and moviemakers to view and organize all their photos and videos from one connected device.
Certain images and effects simulated.
^^ Compatible with Android™ smartphone and tablet versions 4.1/4.2/4.3/4.4/5.0/5.1/6.0/7.0/7.1.
For news photographers capturing hundreds or even thousands of images while moving around throughout the day, landscape photographers on location and even photographers on vacation, GPS has become an indispensable part of a daily workflow. The EOS 5D Mark IV camera’s built-in GPS helps photographers and filmmakers both tag their images with critical location data, and also adjust the time and timestamp on the camera automatically. Featuring both built-in GPS^^^ and Wi-Fi®^ technology, the EOS 5D Mark IV can use GPS and WFT (Wireless File Transfer) together, making it easy to upload numerous images and movies both quickly and from increasingly distant locales. Compatible with American GPS satellites, Russian GLONASS satellites and Japanese quasi-zenith satellites Michibiki, the EOS 5D Mark IV’s GPS information stays reliably accurate in many locations.
^^^ In certain countries and regions, the use of GPS may be restricted. Therefore be sure to use GPS in accordance with the laws and regulations of your country or region. Be particularly careful when traveling outside your home country. As a signal is received from GPS satellites, take sufficient measures when using in locations where the use of electronics is regulated.
^ Compatible with iOS® versions 8.4/9.3/10.2, Android™ smartphone and tablet versions 4.1/4.2/4.3/4.4/5.0/5.1/6.0/7.0/7.1. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
** Compatible with iOS®; versions 8.4/9.3/10.2, Android™ smartphone and tablet versions 4.1/4.2/4.3/4.4/5.0/5.1/6.0/7.0/7.1. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
*** In certain countries and regions, the use of GPS may be restricted. Therefore be sure to use GPS in accordance with the laws and regulations of your country or region. Be particularly careful when traveling outside your home country. As a signal is received from GPS satellites, take sufficient measures when using in locations where the use of electronics is regulated.
| Type | Digital, AF/AE Single-Lens Reflex, Camera |
| Recording Medium |
| Compatible Lenses | Canon EF Lenses (Excluding EF-S And EF-M Lenses) |
| Lens Mount | Canon EF Mount |
| Type | CMOS Sensor (Compatible With Dual Pixel CMOS AF) |
| Pixels | Approx. 30.4 Megapixels |
| Pixel Unit | Approx. 5.36 µm Square |
| Total Pixels | Approx. 31.7 Megapixels |
| Aspect Ratio | 3:2 (Horizontal: Vertical) |
| Color Filter System | RGB Primary Color Filters |
| Low Pass Filter | Installed In Front Of The Image Sensor, Non-Detachable |
| Dust Deletion Feature |
| Recording Format | Complies With Design Rule For Camera File System 2.0 And EXIF 2.3 |
| Image Format | Still Image: JPEG, RAW (14 Bit Canon Original) Video: MOV (4K Video: Motion JPEG; Full HD And HD Movie: MPEG4 AVC/H.264*; Audio: Linear PCM), MP4 (Movie: MPEG4 AVC/H.264*; Audio: AAC) * Variable (Averaged) Bit Rate. |
| File Size | 3:2 Aspect Ratio Large/RAW: Approx. 30.1 Megapixels (6720 X 4480) MRAW: Approx. 16.9 Megapixels (5040 X 3360) Medium: Approx. 13.3 Megapixels (4464 X 2976) Small 1/SRAW: Approx. 7.5 Megapixels (3360 X 2240) Small 2: Approx. 2.5 Megapixels (1920 X 1280) Small 3: Approx. 0.35 Megapixels (720 X 480) 4:3 Aspect Ratio Large/RAW: Approx. 26.7 Megapixels (5952 X 4480)* MRAW: Approx. 15.1 Megapixels (4480 X 3360) Medium: Approx. 11.8 Megapixels (3968 X 2976) Small 1/SRAW: Approx. 6.7 Megapixels (2976 X 2240)* Small 2: Approx. 2.2 Megapixels (1696 X 1280)* Small 3: Approx. 0.31 Megapixels (640 X 480) 16:9 Aspect Ratio Large/RAW: Approx. 25.4 Megapixels (6720 X 3776)* MRAW: Approx. 14.3 Megapixels (5040 X 2836)* Medium: Approx. 11.2 Megapixels (4464 X 2512)* Small 1/SRAW: Approx. 6.3 Megapixels (3360 X 1888)* Small 2: Approx. 2.1 Megapixels (1920 X 1080) Small 3: Approx. 0.29 Megapixels (720 X 408)* 1:1 Aspect Ratio Large/RAW: Approx. 20.1 Megapixels (4480 X 4480) MRAW: Approx. 11.3 Megapixels (3360 X 3360) Medium: Approx. 8.9 Megapixels (2976 X 2976) Small 1/SRAW: Approx. 5.0 Megapixels (2240 X 2240) Small 2: Approx. 1.6 Megapixels (1280 X 1280) Small 3: Approx. 0.23 Megapixels (480 X 480) Values For Recording Pixels Are Rounded Off To The Nearest 10,000th Or 1,000th. JPEG Images Are Generated In The Set Aspect Ratio. RAW Images Are Generated In [3:2], And The Set Aspect Ratio Is Appended. * Inexact Proportion. |
| Recording Functions |
| Backup Recording | N/A |
| File Numbering | The Following Three Types Of File Numbers Can Be Set:
| Raw Jpeg Simultaneous Recording | Possible |
| Color Space | SRGB, Adobe RGB |
| Picture Style |
| Settings | Auto (Ambience Priority/White Priority), Daylight, Shade, Cloudy*, Tungsten Light, White Fluorescent Light, Flash, Custom (Custom WB), Color Temperature * Effective Also In Twilight And Sunset. |
| Auto White Balance | Option Between Ambience Priority And White Priority Settings |
| Color Temperature Compensation | Blue/Amber Bias: ±9 Levels Magenta/Green Bias: ±9 Levels Corrected In Reference To The Current WB Mode's Color Temperature. |
| Color Temperature Information Transmission | Provided |
| Type | Eye-Level SLR (With Fixed Pentaprism) |
| Coverage | Approx. 100% Vertically And Horizontally (At Approx. 21mm Eyepoint) |
| Magnification | Approx. 0.71 |
| Eyepoint | Approx. 21mm (At -1m-1 From The Eyepiece Lens Center) |
| Dioptric Adjustment Correction | Adjustable From Approx. -3.0 To +1.0 M-1 (Dpt) |
| Focusing Screen | Fixed |
| Mirror | Quick-Return Half Mirror |
| Viewfinder Information | Displayed With Transparent Liquid Crystal
| Depth Of Field Preview | Enabled With Depth Of Field Preview Button |
| Type | TTL Secondary Image-Forming Phase-Difference Detection System With AF-Dedicated Sensor | ||||||||||||||||||||||||||||||||||||
| Af Points | AF Points (Max. 61 Points)
The Number Of AF Points, Cross-Type AF Points And Dual Cross-Type AF Points Vary Depending On The Lens Used. |
| Af Working Range | Conditions: One-Shot AF, At 73°F/23°C, ISO 100
| Focusing Modes |
| Af Point Selection |
| Selected Af Point Display | Selected AF Point Display
| Active Af Point Indicator | Displayed In Viewfinder With Transparent LCD And On LCD Panel | ||||||||||||||||||||||||||||||||||||
| Af Assist Beam |
| Metering Modes | 150,000-Pixel RGB+IR Metering Sensor
| Metering Range | EV 0-20 (At 73°F / 23°C , ISO 100) | |||||||||||||||||
| Exposure Control Systems | (1) Scene Intelligent Auto (2) Program AE (Shiftable) (3) Shutter-Priority AE (Safety Shift Possible) (4) Aperture-Priority AE (Safety Shift Possible) (5) Manual Exposure (6) Bulb (7) Custom Shooting Mode C1, C2, C3 |
| Iso Speed Range | Manual Setting (During Viewfinder Shooting)
Auto Setting (During Viewfinder Shooting)
*1 It Depends On [Minimum] And [Maximum] Of [ISO Speed Settings] [Range For Stills]. |
| Exposure Compensation | Manual: ±5 Stops In 1/3 Or 1/2-Stop Increments AEB: ±3 Stops In 1/3 Or 1/2-Stop Increments * Indicated Up To ±3 Stops On The LCD Panel And In The Viewfinder. To Set Exposure Compensation Exceeding ±3 Stops, You Can Use Quick Control. * Live View Shooting, Exposure Compensation Can Be Set Up To ±3 Stops. |
| Ae Lock | (1) Auto AE Lock ·In The One-Shot AF Mode With Evaluative Metering, AE Lock Takes Effect When Focus Is Achieved. (2) Manual AE Lock ·With AE Lock Button. (AE Lock Is Updated Each Time You Press The Button.) Enabled In All Metering Modes. |
| Type | Vertical-Travel, Mechanical, Focal-Plane Shutter With All Speeds Electronically-Controlled | ||||||||||||||||||
| Shutter Speeds | 1/8000 To 30 Sec., Bulb (Total Shutter Speed Range. Available Range Varies By Shooting Mode.) X-Sync At 1/200 Sec. |
| Shutter Release | Soft-Touch Electromagnetic Release | ||||||||||||||||||
| Self Timer | 10-Sec. Self-Timer, 2-Sec. Self-Timer | ||||||||||||||||||
| Shutter Lag Time | Shutter Lag Time
| Eos External Flash Or Dedicated Speedlites | E-TTL II Autoflash With All EX Series Speedlites |
| Zooming To Match Focal Length | Provided |
| Flash Exposure Compensation | ±3 Stops In 1/3- Or 1/2-Stop Increments |
| Fe Lock | Provided |
| External Flash Settings |
| Pc Terminal | Provided (No Polarity) |
| Drive Modes |
| Continuous Shooting Speed | High-Speed Continuous Shooting: Max. Approx. 7.0 Fps
Silent Continuous Shooting: Max. Approx. 3.0 Fps |
| Shooting Modes | Still Photo And Video Recording |
| Focusing |
| Metering Modes |
| Metering Range | EV 0-20 (At 73°F/23°C, ISO 100) |
| Grid Display |
| Exposure Simulation | Possible |
| Silent Shooting | Provided (Mode 1 And 2) |
| File Format | MOV: 4K Video*: Motion JPEG Full HD/HD Movie: MPEG-4 AVC/H.264
MP4: Movie: MPEG-4 AVC/H.264
| File Size | Recording Sizes: 4096 X 2160 (4K)*, 1920 X 1080 (Full HD), 1280 X 720 (HD) |
| Frame Rates | MOV: 4096 X 2160 (4K)*: 30 Fps (29.97 Fps) / 24 Fps / 23.98 Fps 1920 X 1080 (Full HD): 60 Fps (59.94 Fps) / 30 Fps (29.97 Fps) / 24 Fps / 23.98 Fps 1280 X 720 (HD): 120 Fps (119.9 Fps) MP4: 1920 X 1080 (Full HD): 60 Fps (59.94 Fps) / 30 Fps (29.97 Fps) / 24 Fps / 23.98 Fps *4K Requires The Following Write Speed Requirements: CF UDMA7 (100MB/Sec. Or Faster); SD UHS-I (90MB/Sec. Or Higher) |
| Continuous Shooting Time | Continuous Shooting Time MOV
MP4
Bit Rate Indicates Video Output Only, Audio Is Not Included. |
| Focusing |
| Exposure Compensation | Up To ±3 Stops In 1/3-Stop Increments | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Type | TFT Color, Liquid-Crystal Monitor |
| Screen Monitor Size | 3.2-Inch (Screen Aspect Ratio Of 3:2) 3.19 In./8.10cm Diagonal (2.65 In./6.74cm Width, 1.77 In./4.49cm Height) |
| Pixels | Approx. 1.62 Million Dots |
| Coverage | Approx. 100% Viewing Angle: 170° Vertically And Horizontally |
| Brightness Control |
| Coating | Clear View LCD II
| Interface Languages | 25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese) |
| On Lcd Monitor | Electronic Level Indicates Up To 360° Roll And ±10° Pitch In 1° Increments.
| In Viewfinder | Electronic Level Indicates Up To 7.5° Roll Left/Right And ±4° Pitch In 1° Increments.
| Image Display Format | Single Image Display:
| Highlight Alert | With Single-Image Display (Info.) And Single-Image Display, The White Areas With No Image Data Will Blink. |
| Items | Pressing The Quick Control Button Displays The Quick Control Screen During Viewfinder Shooting, Live View Shooting, Movie Shooting And Playback. |
| Protection | Erase Protection Can Be Applied Or Canceled For A Single Image (Select Image), All Images In A Folder Or All Images In The Card. |
| Erase | Erase A Single Image (Playback And Erase Image), Selected Images, All Images In A Folder Or All Images In A Card. |
| Compatible Printers | Images Can Be Sent Via Wi-Fi® To A PictBridge-Compatible (Wireless LAN) Printer And Printed. |
| Printable Images |
| Dpof | Compliant To DPOF Version 1.1 |
| Compatible Images |
| Custom Functions | 17 Custom Functions Settable With The Camera |
| Custom Controls | Functions Can Be Assigned To The Following Buttons:
| Camera User Settings | Current Camera Settings Can Be Registered To C1, C2 And C3 On The Mode Dial. |
| My Menu Registration |
| Usb Terminal | SuperSpeed USB (USB 3.0)
| Video Out Terminal | HDMI Type C (Resolution Switches Automatically), CEC Compatible
| Battery | Battery Pack LP-E6N (Or LP-E6) X 1
| Battery Life | Battery Life (Approx. Number Of Shots)
Based On CIPA Testing Standards. |
| Battery Check | Automatic Battery Check When The Power Switch Is Turned ON. Displayed In 6 Levels.
| Power Saving | Power Turns Off After The Set Time (1, 2, 4, 8, 15 Or 30 Min.) Of Non-Operation Elapses.
| Date Time Battery | Built-In Secondary Battery When Fully-Charged, The Date/Time Can Be Maintained For Approx. 3 Months
| Start Up Time | Approx. 0.96 Sec
| Dimensions W X H X D | Approx. 5.93 X 4.58 X 2.99 In. / 150.7 X 116.4 X 75.9mm |
| Weight | Approx. 31.39 Oz. / 890g (Including Battery, CF Card And SD Memory Card) Approx. 28.22 Oz. / 800g (Body Only; Without Battery, Card, Body Cap And Eyecup) |
| Operating Temperature Range | 32-104°F/0-40°C |
| Operating Humidity Range | 85% Or Less |
Dioptric Adjustment Lens Eg (-4)
The Dioptric Adjustment Lens provides near- and far-sighted users a clear viewfinder image without the use of eyeglasses. The lens fits into the eyepiece holder of you EOS camera. Please see the Compatibility tab for a list of compatible EOS cameras.
Dioptric Adjustment Lens Eg (-3)
Dioptric Adjustment Lens Eg (+3)
Dioptric Adjustment Lens Eg (0)
Dioptric Adjustment Lens Eg (+2)
Dioptric Adjustment Lens Eg (+1)
Dioptric Adjustment Lens Eg (-2)
Remote Control RC-6
Remote Control for EOS cameras.
Wireless Controller for EOS LC-5
Extended range wireless controller system.
Remote Switch RS-80N3
Remote switch for EOS cameras with the N3-type socket to prevent camera shake for super telephoto shots, macro photography shots and bulb exposures. The Remote Switch works just like a shutter button, enabling halfway or complete pressing. It has a shutter-release lock and a 2.6ft/80cm cord.
Wireless Transmitter WFT-E7E (VER.2)
Wireless LAN support for IEEE802.11 a/b/g/n, delivering ultra-fast image transfer speed. Support for wired LAN Ethernet-1000BASE-T for high speed communication. Media server (DLNA) supported. Bluetooth compatible GPS devices can be connected wirelessly.
Timer Remote Controller TC-80N3
Remote switch for EOS cameras with the N3-type socket. This remote switch has a self-timer, interval timer, long exposure timer and exposure-count setting feature. The timer can be set from 1 second to 99 hours. A new dial enables you to easily enter the numeric settings with a single thumb. It has an illuminated LCD panel and a 2.6ft/80cm cord.
Protecting Cloth PC-E1
The Protecting Cloth is for the purpose of protecting equipment such as a camera and lens from dirt and scratches, etc., but it cannot protect equipment from shocks or pressure.
Wide Strap EW-100 DB IV
Wide strap for EOS Cameras.
Car Battery Charger CBC-E6
Car battery charger for Canon EOS Digital SLR LP-E6 battery.
Battery Charger LC-E6
Battery Charger for NP-E6 Li-ion Batteries.
DC Coupler DR-E6
When shooting indoors, in a studio or on a tabletop, use this DC coupler to provide uninterrupted power to your Canon Digital SLR.
AC Adapter AC-E6N
Provides AC power to the camera with the combination of DR-E6.
Battery Grip BG-E20
This large capacity battery grip is powered by two Battery Pack LP-E6 batteries or an optional DC Coupler DR-E6 and AC Adapter AC-E6N. It features a variety of operating controls, and is ideal for high volume and vertical shooting.
Battery Pack LP-E6N
Rechargeable lithium-ion battery. Compatible with Canon LC-E6 and Canon LC-E6E battery chargers.
Eyecup Eg
Canon Eyecup EG for EOS Digital Cameras.
Anti-Fog Eyepiece Eg
The Anti-Fog eyepiece uses specially treated advanced-process glass, which prevents condensation or fogging. Designed for use in warm and humid or cold weather when fogging is most likely to occur, and attaches easily to reduce condensation and help you maintain a clear view of your subject.
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
