EOS-1D C
- First ever 4K Canon DSLR
- A wide range of output options
- Amazing low-light performance
- Compact and rugged design for versatile application possibilities
- EOS-1D C Body
- Eyecup Eg
- Battery Pack LP-E4N
- Battery Charger LC-E4N
- Cable Protector and Clamp
- Stereo AV Cable AVC-DC400ST
- USB Interface Cable IFC-200U
- Wide Strap L7
- EOS Digital Solution Disk
- Software Instruction Manual
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The EOS-1D C is an HD video powerhouse providing cinematographers 4K video capture in a single unit, with no need for external power or recording devices. The EOS-1D C is fully self-contained, with the ergonomic ease-of-use portability one expects from a Canon DSLR. Control layout is intuitive for both still and video shooting and the compact size provides an unobtrusive method to getting your desired footage. The EOS-1D C is also fully sealed for protection against dust and moisture.
The EOS-1D C carries the latest generation of Canon's Full-Frame CMOS sensor. With a Full-Frame sensor, Canon EF and EF Cinema lenses will perform to their true potential, while improved signal-to-noise ratio provide clearer shadows and highlights in both bright and low-light environments. Achieve high quality results across the ISO range from 100 to 51200, expandable from ISO 50 to 204800. The sensor in the EOS-1D C also minimizes the rolling shutter effect with a high-speed read across the sensor bus for true-to-life images.
The EOS-1D C is a completely self-contained device that captures 4K video in a cropped-sensor configuration at 24fps in YCbCr color space with a sampling ratio of 4:2:2 and 8-bit depth. Color and luminescence are preserved, while footage can easily adapt to existing post-production workflows without conversion. 4K video can be monitored on the camera's rear LCD, or HD video can be output via HDMI to an external recorder for proxy editing. 4K files can also be played in native resolution using the EOS MOVIE Player.
In addition to standard frame rates of 30fps, 25fps and 24fps, the EOS-1D C also enables Full HD recording at 60fps and 50fps and supports high-speed shooting for spectacular slow-motion footage. The camera's built-in LCD monitor can both preview and play back footage at its native frame rate. The EOS-1D C also supports Super 35mm Crop in Full HD at 30fps, 25fps, and 24fps. Image compression is H.264 and HDMI support permits external monitoring and playback of footage independent of shooting mode. When monitoring Super 35mm Crop images, the monitor automatically masks the image to aid composition.
The EOS-1D C utilizes dual DIGIC 5+ Image Processors for stunning speed and image quality. Each DIGIC 5+ Image Processor contains twin 4-channel A/D converters for outstanding image quality, and refined algorithms reduce noise at high ISO values. The EOS-1D C also applies real-time correction of chromatic aberration and other optical artifacts based on data stored in-camera. Lens data can be added and deleted by using the included EOS Utility software.
Canon Log Gamma is a setting that sets the EOS-1D C to maximize dynamic range and provide a wide exposure latitude. The files produced using log format are ideal for post-production processes where corrections, color matching, and grading are applied, providing users with a high level of creative freedom in post-production without substantially degrading image quality. When using Canon Log, the EOS-1D C can provide a dynamic range of up to 800%.
The EOS-1D C offers several new capabilities via HDMI output. Connect via HDMI to an external video recorder and output uncompressed YCbCb 4:2:2 8-bit video footage. Output frame rate is independent of shooting rate, allowing it to be matched to the capabilities of the external recorder. HDMI output supports Full HD video, even when recording 4K video to the on-board CF cards. Time code is embedded into the footage for easy synchronization of audio or visual effects. Camera control is also enabled via HDMI; the transport controls on the external recorder can be used to control the camera remotely. In addition, footage can be previewed simultaneously on the camera's LCD monitor and via the HDMI output for multiple monitoring options.
The EOS-1D C is compatible with the full line of Canon EF lenses, including EF Cinema lenses (Cinema zooms are compatible only in Super 35mm Crop mode; Cinema primes are compatible in all modes). Ultra-wide, zoom, 4x macro, tilt-shift, and super-telephoto lenses in the EF line are tools to realize your most ambitious cinematic vision. EF Cinema Lenses merges the technology of advanced Canon cinema optics and compatibility with a broad array of industry-standard accessories.
The EOS-1D C includes a built-in headphone terminal which outputs unprocessed sound, giving you the clear audio image while the camera is recording it.
The EOS-1D C can connect to an optional Wi-Fi® transmitter unit WFT-E6A to provide unique capabilities not found in competitive units. Users can control the EOS-1D C using any web-enabled devices such as laptops, smartphones, and tablet PC's. Functions of the EOS-1D C with the WFT-E6A include the ability to adjust shooting parameters, start and stop the camera, monitor a remote feed and input metadata. Bluetooth v2.1 +EDR communicates with external GPS units to embed location data with your footage.
The EOS-1D C shares its heritage with the EOS-1 Series family and is a world-class DSLR camera besides being a cinema powerhouse. Dual DIGIC 5+ Image Processors and an 18.1 Megapixel Full-Frame CMOS sensor provide a burst shot rate of 12.0 fps for capturing the action with exceptional quality. With ISO sensitivity ranging from 100 to 51200, expandable to L: 50, H1: 102,400, H2: 204,800, the EOS-1D C allows you to grab the best possible shot even in the most challenging lighting. The 61-Point High-Density Reticular autofocus system with a coordinated 100,000 pixel RGB metering system provides sharp images with incredible color and clarity.
| Power Supply Rated | DC 7.4 V (Battery Pack) / DC 8.4 V (DC In) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Recording Codec | Resolution
Recording Options
Slow And Fast Motion Recording Available; Records At A Different Frame Rate Then The Playback Rate Allowing For Fast And Slow Motion Effects: (Slow And Fast Motion Recording Is Available In 4K And 2K Modes To External Recording Devices.)
| Image Sensor | CMOS; Super 35; 26.2 X 13.8 (29.6 Mm Diagonal); 6.4 µm Cell Pitch | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Effective Pixels | 4096 X 2160 Pixels; Approx. 8.85 Megapixels | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Total Pixels | 4206 X 2340 Pixels; Approx. 9.84 Megapixels | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Max Movie Recording Time |
| Lens | Compatibility With EF, EF-S And EF Cinema Lens Systems | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Focusing System | Manual | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| White Balance | Kelvin Setting 2,000K To 15,000K In 100K Increments | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Minimum Illumination | 59.94 Hz Mode: 0.3 Lux (F/1.2, 24 DB, 29.97p, 1/30 Sec.) 50.00 Hz Mode: 0.25 Lux (F/1.2, 24 DB, 25p, 1/25 Sec.) |
| Genlock Terminal | Yes; BNC Connector (Input Only) Adjustment Range: -1023 To +1023 |
| Hd Sd Sdi Terminal | Yes; (With Embedded Audio); HD 8-Bit 4:2:2 (YPbPr) 1920x1080: 59.94i/50i/23.98/24.00, 1280x720: 59.94p/50p/23.98/24.00 SD 8-Bit 4:2:2 (YPbPr) 480: 59.94i, 576: 50i BNC Connector, Output Only SD-SDI: |
| Timecode Terminals | Yes; BNC Connector (Input And Output) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Lcd Screen Monitor Unit | Rotating 4 Inch Wide Screen Color LCD Display (1,230,000 Dots: 854x480) On Detachable Controller | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Recording Media | CF Card (Type 1 Only); 2 Slots (Movie Files); UDMA Supported SD Card (Still Images (JPEG), Custom Picture Data*, Clip Metadata, And Menu Settings); SD/SDHC/SDXC Supported; MMC Cards Are Not Supported * Custom Picture Data And Settings Is Not Compatible With Data From Others Canon Models |
| Audio Terminal | 2 - Balanced 3-Pin XLR On Monitor Unit (Mic Level, Mic Level With Phantom Power And Line Level) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Hdmi Terminal | Yes (Type A) HD 8-Bit 4:2:2 (YPbPr) 1920x1080: 60i/59.94i/50i, 1280x720: 60p/59.94p/50p SD 8-Bit 4:2:2 (YPbPr) 480: 59.94i, 576: 50i | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Operating Temperature Range | -5°C To 45°C, 60% (Relative Humidity) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Dimensions W X H X D | Approx. 6.3 X 7.0 X 6.7 In (160 X 179 X 171 Mm) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Weight Not Including Lens | C500 Body: Approx. 4.0 Lb. (1820 G) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
