EF 600mm f/4L IS II USM
- Fluorite optics that deliver sharper images with less chromatic aberration
- Magnesium and titanium construction for a lighter weight
- Advanced third Image Stabilization mode (Mode 3)
- Power Focus mode enables smooth focus change when shooting video
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Featuring Fluorite optics that deliver sharper images with less chromatic aberration, the new large-diameter EF 600mm f/4L IS II USM super telephoto lens also takes advantage of magnesium and titanium construction for a lighter weight and a Fluorine coating that keeps soiling, smears and fingerprints to a minimum. Because image stabilization technology in super telephoto lenses may inadvertently over-compensate and interfere with composing and framing distant or moving subjects, the EF 600mm f/4L IS II USM includes an advanced third Image Stabilization mode (Mode 3) that activates IS only when the shutter button is fully pressed. This allows users to pan fast-moving subjects and then activate IS only when it is precisely required. Because all three IS modes give the equivalent effect of up to four extra stops of performance, and because plus the Power Focus mode enables smooth focus change when shooting video, the EF 600mm f/4L IS II USM is ideal for capturing rapid-fire action. Other improvements such as better dust- and waterproofing make the Canon EF 600mm f/4L IS II USM super telephoto lens an ultra high-performance Digital Age tool combining Canon hallmarks of superb ease-of-use with excellent durability.
Sample Image
MTF Charts
| Focal Length Maximum Aperture | 600mm F/4.0 |
| Lens Construction | 16 Elements In 12 Groups (Including Drop-In Rear Filter, Fluorite: G2 And G4, UD Lens: None) |
| Diagonal Angle Of View | 4°10' |
| Focus Adjustment | Inner Focusing System, With Focusing Cam |
| Closest Focusing Distance | 4.5m / 14.77 Ft. |
| Filter Size | 52mm Drop-In |
| Max Diameter X Length Weight | 6.6" X 17.6", 138.3 Oz. / 168 X 448mm, Approx. 3920g |
Raincover Large
Keeps your professional camera clean and dry when shooting in a wet environment. Compatible with Canon EOS Cameras. Contains attachable eyecups (L,S) for compatibility with all EOS Digital cameras. Transparent window enables clear visibility of the top and rear LCD panels and LC monitor. Front fastener enables easy attachment and removal of all lenses.
Extension Tube EF-12 II
Extension Tube EF 12 II is especially suited for close-focusing with wide-angle lenses.
Extender EF 1.4x III
Extending a lenses focal length by a factor of 1.4x, Extender EF 1.4X III incorporates phenomenal optical performance with minimal chromatic aberration and is a perfect complement to many of Canon super telephoto lenses. The Fluorine coating resists soiling, smears and fingerprints. Extender EF 1.4X III maintains high standards not only optically, but also in terms of rugged, dustproof and water resistant construction.
Extension Tube EF-25 II
25mm fully coupled Extension Tube for EOS camera and most lenses to 350mm.
Extender EF 2x III
Designed to extend a lenses focal length by a factor of 2x, the Canon Extender EF 2X III delivers optical performance on par with the finest Canon super telephoto lenses. It delivers seamless communication among camera body, lens and extender, and features coatings to minimize ghosting, flare and chromatic aberration. The Fluorine coating resists soiling, smears and fingerprints. Extender EF 2X III meets all necessary standards in terms of rugged, dustproof and water-resistant construction, and should be in every professional's camera bag.
Lens Hood ET-160WII
Lens Case 600B
Lens Dust Cap E Rear Cap
Rear lens cap for all EF type lenses, lens extenders, and extension tubes. Used to protect the rear glass element from dust and scratches.
Lens Cap E-185B
Lens Wide Strap
Fits Many Long Telephoto Lenses.
52mm Drop-in Circular Polarizing Filter PL-C 52
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Locating and Installing Your Download Cómo Localizar e Instalar su Descarga Localizando e Instalando seu Download
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
