Ultra-wide-angle lens for serious applications. Easy to hold and carry at 14.3 oz. / 405g. Floating rear focusing system. Sharp images are obtained at all subject distances.
Sample Image
MTF Chart
Focal Length Maximum Aperture
20mm F/2.8
Lens Construction
11 Elements In 9 Groups
Diagonal Angle Of View
94°
Focus Adjustment
Rear Focusing System With USM
Closest Focusing Distance
0.25m / 0.8 Ft.
Filter Size
72mm
Max Diameter X Length Weight
3.1" X 2.8", 14.3 Oz. / 77.5 X 70.6mm, 405g
Lens Extenders / Close Up / Conversion Adapters
Extension Tube EF-12 II
Extension Tube EF 12 II is especially suited for close-focusing with wide-angle lenses.
Cases / Lens
Lens Case LP1214
Lens / Hoods
Lens Hood EW-75II
Designed to prevent stray light from entering the lens in order to keep unwanted glare from affecting your photographs.
Lens Caps
Lens Dust Cap E Rear Cap
Rear lens cap for all EF type lenses, lens extenders, and extension tubes. Used to protect the rear glass element from dust and scratches.
Lens Cap E-72 II
The Lens Cap E-72 II is newly designed and fits Canon EF lenses with a 72mm filter size. It helps protect the front glass from dust and scratches.
Lens Cap E-72U
Indispensable for protecting your valuable lenses, this cap should be used on all lenses with a 72mm filter size.
Lens Filters
72mm Circular Polarizer PL-CB
Polarizing filters enhance picture quality by blocking harmful reflected light. Use it to reduce light reflections from glass and water surfaces or to improve color saturation. Simple to use, these filters polarize light circularly, rather than linearly, so they do not interfere with autofocus or TTL light metering.
