Color imageRUNNER LBP5480
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Powerful Processing Engine:
Superb Image Quality:
New User Interface:
USB Direct Print:
Front-Load Access:
Consistent imageRUNNER Print Driver Architecture:
Printing Options:
RAPID Fusing System:
Unleash new workflows with MFP integration:
Optimized for fleets and Managed Document Services (MDS):
| Model Name | Color ImageRUNNER LBP5480 |
| Type | Desktop Laser Printer Printing Method: Electrophoto Method (Color RAPID Fusing System) |
| Developing System | Contact Developing System |
| Image Server Memory | Standard/Maximum 768MB RAM CPU: ARM11-528 MHz + ARM9-264 MHz |
| Network Interface Connection | Shared 10Base-T/100Base-TX/1000Base-T (Device) |
| Other Interface | USB Hi-Speed (Device) X1 / USB Hi-Speed (Host) X2 User Interface: LCD 22 Characters X 5 Lines, 8 LED Indicators, 12 Operation Keys |
| Printing Resolution | UFR II, PCL 5c/6, PostScript 3: 600 X 600 Dpi, 9600 Dpi Equivalent X 600 Dpi Engine: 600 X 600 DpiPrint Drivers: UFR II, PCL 5c/6, PostScript 3: Windows® (XP/Windows Vista®/Windows 7/Windows 8/Server 2003/Server 2008/ Server 2008 R2/Small Business Server 2011/Server 2012), Windows Terminal Servers (Server 2003/Server 2008/Server 2008 R2/Small Business Server 2011, Server 2012), Microsoft® Failover Cluster (Server 2003/Server 2008/Server 2008 R2),Citrix (Presentation Server 4.5, XenApp 5.0/6.0/6.5, XenDesktop 4.0/5.0/5.5/5.6), Macintosh® (OS X 10.5.8 Or Later) (UFR II/ PostScript 3 Only), VMware (VSphere 4, 5), SAP (PCL 5c/6, PostScript 3 Only |
| Halftone | 256 Gradations (Continuous-Tone) |
| Letter | (BW/Color): Up To 33 Ppm |
| First Copy Time | BW Printing: 10.2 Seconds Or Less Color Printing: 10.4 Seconds Or Less |
| Maximum Original Size | Legal (8-1/2" X 14") |
| Standard Paper Capacity | 500-Sheet Paper Cassette (20 Lb. Bond) 100-Sheet Multi-Purpose Tray 100-Sheet Multi-Purpose Tray |
| Optional | 500-Sheet Paper Cassette |
| Maximum Paper Capacity | 1,100 Sheets |
| Output Paper Capacity | Face-Down Output Tray: Approx. 250 Sheets Paper Output: Face-Down |
| Duplexing | Standard Automatic Trayless Duplexing (Legal, Letter) |
| Paper Size | Drawer: Standard Sizes: Letter, Executive,** Statement Custom Sizes: In Case Of Portrait Orientation (Only When The UFR II Printer Driver Is Used): Short Edges 5-7/8" To 8-1/2"; Long Edges 5-7/8" To 8-1/2" In Case Of Landscape Orientation: Short Edges 4" To 8-1/2" ***; Long Edges 5-7/8 To 11-5/8" *** Drawer: Standard Sizes: Legal, Letter, Executive, Foolscap, And 16K Custom Sizes: In Case Of Portrait Orientation (Only When The UFR II Printer Driver Is Used): Short Edges 8-1/4" To 8-1/2"; Long Edges 8-1/4" To 8-1/2" In Case Of Landscape Orientation: Short Edges 5-7/8" To 8-1/2"; Long Edges 8-1/4" To 14" Multi-Purpose Tray: Standard Sizes: Legal, Letter, Executive, Statement, Foolscap, 16K, Index Card, Envelope (DL, No. 10, ISO-C5, And Monarch) Custom Sizes: In Case Of Portrait Orientation (Only When The UFR II Printer Driver Is Used): Short Edges 5" To 8-1/2"; Long Edges 5" To 8-1/2" In Case Of Landscape Orientation: Short Edges 3" To 8-1/2"; Long Edges 5" To 14" |
| Paper Weight | Cassette: 16 Lb. Bond To 43 Lb. Bond (60 - 163 G/M2) Multi-Purpose Tray: 16 Lb. Bond To 80 Lb. / Cover (60 - 216 G/M2) Optional Cassette: 16 Lb. Bond To 47 Lb. Bond (60 - 176 G/M2) |
| Estimated Toner Yield | Black/Starter: 12,000 Pages/6,100 Pages YMC: 6,400 Pages |
| Description | Paper Feeder Unit PF-723A |
| Acceptable Originals | Standard Sizes: Legal, Letter, Executive, Foolscap, And 16K Custom Sizes: In Case Of Portrait Orientation (Only When The UFR II Printer Driver Is Used): Short Edges 8-1/4" To 8-1/2;" Long Edges 8-1/4" To 8-1/2" In Case Of Landscape Orientation: Short Edges 5-7/8" To 8-1/2;" Long Edges 8-1/4" To 14" |
| Capacity | 500 Sheets (20 Lb. Bond) |
| Dimensions | 6-3/8" X 20-1/4" X 20" (163mm X 514mm X 506mm) |
| Weight | Approx. 17.6 Lb. (8 Kg)Other Optional Accessories
** When Width Is 8-1/2", Max Length Is 11". *** When Length Is 11-5/8", Max Width Is 8-1/4". **** Toner Cartridge Yield In Accordance With ISO/IEC 19798. ♦ One Paper Feeder Unit Can Be Added. |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
