Color imageRUNNER C1335iF
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Compact Performance:
Remarkably Easy to Use:
Consistent Print Language and Architecture:
Brilliant Color:
Standard Document Distribution:
Enhanced Authentication and Security:
Easy Maintenance:
Simplified Device Management:
Ready for Managed Print Services:
| Model Name | Color ImageRUNNER C1335iF |
| Type | Color Digital Multifunction Imaging System |
| Functions | Copy, Print (UFR II, PCL 5c/6, Adobe® PostScript® 3™), Fax (Up To 1 Line), Scan, Send |
| Operation Panel | 3.5" QVGA Color Touch Panel |
| Image Server Memory | Standard: 1 GB RAM Maximum: 1 GB RAM |
| Network Interface Connection | Ethernet 10/100/1000Base-TX |
| Other Interface | USB 2.0 X2 (Host), USB 2.0 (Device) |
| Network Twain Scan | Standard: Network WIA Scan |
| Network Scan Utility | Color Network ScanGear 2 |
| Letter | Up To 36/36 Ppm |
| Legal | Up To 29/29 Ppm |
| First Copy Time | As Fast 5.9 Seconds (BW) And 7.4 Seconds (Color) |
| Multiple Copies | 1 To 999 |
| Copy Exposure | Automatic Or Manual (9 Levels) |
| Magnification | 25 - 400% (1% Increments) |
| Preset Reductions | 25%, 50%, 64%, 78% |
| Preset Enlargements | 129%, 200%, 400% |
| Standard Paper Capacity | (20 Lb. Bond): 550-Sheet Paper Cassette 100-Sheet Stack Bypass |
| Optional | 1 X 550-Sheet Paper Cassette 3 X 550-Sheet Paper Cassette |
| Maximum Paper Capacity | 2,300 Sheets |
| Output Paper Capacity | (21 Lb. Bond): Standard: 250 Sheets |
| Cassettes | Legal, Letter, Statement, Executive, Custom Size [(3-7/8" X 7-1/2" To 8-1/2" X 14") (98.4 Mm X 190.5 Mm To 216 Mm X 355.6 Mm)], And Envelopes (COM10, Monarch, DL, ISO-C5)* |
| Bypass | Legal, Letter, Statement, Executive, Custom Size [(3-7/8" X 5-7/8" To 8-1/2" X 14") (98.4 Mm X 148 Mm To 216 Mm X 355.6 Mm)], And Envelopes (COM10, Monarch, DL, ISO-C5) |
| Cassette | 16 Lb. Bond To 60 Lb. Cover (60 To 163 G/M2) |
| Bypass | 16 Lb. Bond To 80 Lb. Cover (60 To 220 G/M2) |
| Paper Size | Standard Automatic Trayless Duplexing (Statement To Legal) |
| Paper Weight | Up To 60 Lb. Cover (163 G/M2) |
| Warm Up Time | From Power On: 34 Seconds From Sleep Mode: 10 Seconds Quick Startup Mode: 10 Seconds** |
| Power Requirements | 120 V, 60 Hz, 7.5 A 220-240 AC, 50/60HZ, 3.7 A |
| Power Consumption | Maximum: 1.5 KW Sleep Mode: 1 W |
| Dim | 24.02" X 20.12" X 22.20" (610 Mm X 511 Mm X 564 Mm) |
| Installation Space | 32.09" X 33.78" ( 815 Mm X 858 Mm) (When The Multipurpose Tray And Cassette Are Open) |
| Weight | Approx. 96.8 Lb. (44 Kg)*** |
| Scan Resolution | Up To 600 X 600 Dpi |
| Acceptable Originals | (Glass): Sheet, Book, 3-Dimensional Objects [Up To 4.4 Lb. (2 Kg)] |
| Maximum Original Size | Legal (8-1/2" X 14") |
| Standard S | Department ID Management, Secured Print, IPv6, Send To Myself (Only), Send To My Personal Folder (Only), SSL Encrypted Communication, SNMPv1/V3, MAC/IP Address Filtering, SMTP Authentication, POP Authentication Before SMTP, IPsec |
| Environmental Features |
| Estimated Toner Yield | BW: 16,500 Images Color (C,M,Y): 11,500 Images |
| Description | Document Feeder |
| Acceptable Originals | Paper Size: Legal, Letter, StatementPaper Weights: 1-Sided Scanning (Single Sheet): 13 Lb. Bond To 34 Lb. Bond (50 To 128 G/M2) 1-Sided Scanning (Multiple Sheets): 13 Lb. Bond To 28 Lb. Bond (50 To 105 G/M2), 2-Sided Scanning: 17 Lb. Bond To 28 Lb. Bond (64 To 105 G/M2) |
| Scan Method | Duplexing Automatic Document Feeder |
| Scanning Speed | Simplex: 36 Ipm (300 Dpi)/23 Ipm (600 Dpi) Duplex: 11 Ipm (300 Dpi)/9 Ipm (600 Dpi) |
| Capacity | (20 Lb. Bond): 50 Sheets |
| Description | Cassette Feeding Unit-AJ1 |
| Paper Capacity | 550 Sheets [21 Lb. Bond (80 G/M2)] |
| Paper Size | Legal, Letter, Statement, Executive, Custom Size [3-7/8" X 7-1/2" To 8-1/2" X 14" (98.4 Mm X 190.5 Mm To 216 Mm X 355.6 Mm)] |
| Paper Weight | 16 Lb. Bond To 60 Lb. Cover (60 To 163 G/M2) |
| Power Source | From The Main Unit |
| Power Consumption | Approx. 25 W |
| Dimensions | 16-3/4" X 20-1/8" X 20" (425 Mm X 511 Mm X 508 Mm) |
| Weights | Approx. 33.1 Lb. (15 Kg) |
| Description | Cassette Feeding Unit-AK1 |
| Paper Capacity | 550 Sheets X 3 Cassettes [21 Lb. Bond (80 G/M2) |
| Paper Size | Legal, Letter, Statement, Executive, And Custom Size [3-7/8" X 7-1/2" To 8-1/2" X 14" (98.4mm X 190.5mm To 216mm X 355.6mm)] |
| Power Consumption | Approx. 35W |
| Dimensions | 16-3/4" X 20-1/8" X 20" (425mm X 511mm X 508mm) |
| Weights | Approx. 41.9 Lb (19kg) |
| Applicable Line | Standard:1 Maximum: 1 |
| Modem Speed | Super G3: 33.6 Kbps G3: 14.4 Kbps |
| Processor | Canon Dual Custom Processor (Shared) |
| Engine Resolution | 600 X 600 Dpi |
| Pdl Support | UFR II, PCL 5c/6, Adobe PostScript 3 |
| Sending Method | E-Mail, File Server (FTP, SMB, WebDAV), Super G3 Fax |
| Color Mode | Auto Color Select (Color, Gray), Auto Color Select (Color, Black) Full Color, Grayscale, BW |
| Scan Resolution | BW: 600 X 600 Dpi, 400 X 400 Dpi, 300 X 300 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi, 150 X 150 Dpi, 100 X 100 Dpi Color:300 X 300 Dpi, 200 X 200 Dpi, 200 X 100 Dpi, 150 X 150 Dpi, 100 X 100 Dpi |
| Communication Protocol | File: FTP (TCP/IP), SMB (TCP/IP) E-Mail: SMTP, POP3 |
| File Format | Standard: TIFF, JPEG, PDF, PDF (Compact), PDF (OCR) |
| I Fax Data Format | Other Optional Accessories:
* Envelopes Supported From First Cassette With Included Envelope Feeder Attachment. ** If "Quick Startup Settings For Main Power" Is Set To On, It Takes 10 Seconds Until The Key Operation On The Touch-Panel Display Is Available After Turning On The Main Power. *** Including Consumables. |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
