Color imageCLASS MF8580Cdw
- Color imageCLASS MF8580Cdw product
- Setup Instructions
- Power Cord
- Telephone Cable
- Registration Card
- Starter Cartridge 118
- Manuals
- User Software CD-ROM
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The Canon Color imageCLASS MF8580Cdw is loaded with easy to use features, outstanding color output and multifunction capabilities.
The color imageCLASS MF8580Cdw ensures efficiency with its 4-in-1 functionality. With print, copy, scan and fax capabilities you can accomplish all necessary tasks with just one machine. With an array of easy to use features, such as the 7-line color LCD and Simple Solution Keys, your daily workflow will be a breeze.
The MF8580Cdw is equipped with features to help you keep up with the mobility of your lifestyle. With Canon Mobile Printing8 you can easily print a variety of file types from your iPhone® or iPad® and enjoy the convenience of different finishing options, such as two-sided printing and multiple copies. Additionally, the MF8580Cdw is Google Cloud Print™9 compatible, helping you to keep up with your on-the-go needs.
Easily navigate through the many features with the 7-line color LCD display. The clear, intuitive display ensures a smooth workflow, letting you focus on the most important tasks at hand. The Simple Solution Keys located on the control panel make scanning effortless and give you easy access to Eco-Copy options and Secure Print.
The MF8580Cdw is also equipped with a wide range of security features, such as Secure Print and Department ID Management. With Secure Print, users can be sure that their confidential documents end up in the right hands. Printed documents will not be released until a unique code is entered into the machine. Department ID Management allows you to control and monitor device usage, which can also help to reduce costs.
Your professional quality color documents are printed at speeds of up to 21 pages per minute1 in both color and black and white with a quick first print time of 14.3 seconds. With the Superior Color Imaging Technologies built into the MF8580Cdw your printed materials will be crisp and vibrant.Wireless Connectivity - print from almost anywhere in your home or office
Easily access the scan, eco-copy, and secure print functions right from the control panel with the Simple Solution Keys
Navigate through all the features seamlessly with the 7-line color LCD display
Reduce paper consumption with two-sided printing, copying, scanning, and PC faxing
Send scanned documents and forward received faxes to a recipient through e-mail or file server
Print a variety of file types from your iPhone® or iPad® with the free Canon Mobile Printing app
Google Cloud Print™ Ready for printing on the go
Enjoy easy paper handling with the 250-sheet front-loading cassette and 50-sheet multipurpose tray
Print documents, web pages, emails and photos from your iPad, iPhone and iPod touch using Apple Air Print™
- Print speed is based on internal testing. Print speed may vary depending on the number of copies selected, as well as on the settings for size, type and orientation of paper.
- May vary depending on the output environment.
- Letter size, after being restored from energy saver mode.
- The Public Switched Telephone Network currently supports fax modem speeds of 28.8 Kbps or lower, depending on telephone line conditions. Sending and receiving fax machines need to conform to ITU-T v.34 guidelines.
- Based on ITU-T #1 Chart (standard mode).
- Based on 20 lb. bond paper.
- Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
- Requires Canon Mobile Printing app available free on the App store. Compatible with iPhone 5, iPhone 4S, iPhone 4, iPad mini, iPad 4, the new iPad, iPad 2, and the original iPad running OS 6.0.1 - 6.1.2
- Requires an Internet connection and Google Account. Printer firmware update may be necessary for Google Cloud Print™ function. Certain exceptions may apply. A PC running Windows XP or later or A Mac running OS 10.4.11 or later and USB cable required to perform firmware update.
- AirPrint™ functionality requires an iPad, iPad Mini, iPad 2, the new iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint™-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base Station, or Time Capsule is not supported.
| Printer Type | Color Laser |
| Print Speed | Up To 10ppm (2-Sided Plain Paper Letter)1 Up To 21ppm (1-Sided Plain Paper Letter)1 |
| First Print Time | 14.3 Seconds Or Less (Letter)2 |
| Printer Language | UFR II LT (Host-Based), PCL6(5e,XL) |
| Print Resolution | Up To 1200 X 1200 Dpi (2400 X 600 Dpi Quality) |
| Maximum Print Size | Up To Legal |
| Duplex Print | Yes, Automatic |
| Print Modes | Watermark, Toner Save, Page Composer, Poster, Booklet |
| Print Memory | 512 MB (Shared) |
| Copy Type | Color Laser |
| Copy Speed | Up To 21cpm (Letter) |
| Duplex Copy Speed | Up To 10cpm (Letter) |
| Copy Resolution | Up To 600 X 600 Dpi |
| Original Type | Text/Photo/Map |
| Halftones | 256 Levels |
| Warm Up Time | Approximately 23 Seconds |
| First Copy Time | Black: Approx. 15.3 Seconds (Letter)3 Color: Approx. 16.0 Seconds (Letter)3 |
| Recovery Time | Approximately 8 Seconds |
| Maximum Number Of Copies | 99 Copies |
| Duplex Copy Bind Time | Yes |
| Reduction Enlargement | 25 - 400% In 1% Increments |
| Zoom | 25 - 400% In 1% Increments |
| Copy Size | Platen: Up To Letter ADF: 5.5" X 5" To Legal |
| Copy Features | Collate 2 On 1 4 On 1 ID Card Copy Frame Erase |
| Copy Memory | 512 MB (Shared) |
| Modem Speed | Up To 33.6 Kbps (Super G3)4 |
| Fax Resolution | Up To 406 X 391 Dpi (Super Fine) |
| Transmission Time | JBIG (Approx. 3 Seconds) |
| Memory Capacity | Up To 512 Sheets5 |
| Speed Dials | 181 Coded Dials |
| Group Dialing | 199 Destinations |
| Sequential Broadcasting | 210 Destinations |
| Duplex Fax | Yes (TX & RX) |
| Receive Modes | FAX Only, Manual, Answering, Fax/Tel Auto Switch |
| Fax Features | Remote RX, Dual Access, Distinctive Ring Pattern Detection, Error Correction Mode, Auto Redial |
| Activity Reports | Activity Result & Activity Management |
| Pc Fax | Sending Only |
| Fax Forwarding | FAX -> FAX, EMAIL, SMB |
| Scan Type | Color Contact Image Sensor (CIS) |
| Color Depth | 24-Bit |
| Scan Resolution | Up To 600 X 600 Dpi (Optical) 9600 X 9600 (Interpolated) |
| Scan Size | Platen: Up To Letter ADF: 5.5" X 5" To Legal |
| Duplex Scan | Yes |
| Compatibility | TWAIN, WIA |
| Output File Formats | PDF(Compact), PDF, JPEG, TIFF |
| Scan Features | Scan To USB |
| Pull Scan | USB And Network |
| Push Scan Scan To Pc | USB And Network |
| Scan To Email | Yes (PDF, Compact PDF) |
| Scan To Smb | Yes (JPEG, TIFF, PDF, Compact PDF) |
| Standard Paper Source | 250-Sheet Cassette Plus 50-Sheet Multipurpose Tray6 |
| Optional Paper Source | 250-Sheet Cassette6 |
| Document Feeder | 50-Sheet Duplex6 |
| Paper Output | 125 Sheets (Face Down) |
| Paper Weight | 16-58 Lb. Bond (Cassette) 16-58 Lb. Bond (Multipurpose Tray) |
| Media Sizes | Letter, Legal, A4, A5, B5, B6, Statement, Executive |
| Media Types | Plain Paper, Heavy Paper, Recycled, Transparency, Label, Envelope, Index, Color, Coated |
| Envelope Capacity | 10 Envelopes |
| Envelope Types | Com 10, Monarch, DL, C5, B5 |
| Standard Interface | USB Device 2.0 Hi-Speed, 10/100 Base-T Ethernet, 802.11 B/G/N Wireless7 |
| Wifi Access Mode | Infrastructure Mode |
| Wifi Authentication Methods | Open System, Shared Key, WPA-PSK, WPA2-PSK |
| Wifi Encryption Modes | WEP (64/128 Bit), TKIP, AES |
| Wps Easy Setup Support Methods | Push-Button Mode, PIN Code Mode |
| Usb Functions | Canon Mobile Printing8, Google Cloud Print™9, Apple AirPrint™10 |
| Mobile Functions | Canon Mobile Printing9, Google Cloud Print™10, Apple AirPrint™11 |
| Network Functions | Print, Copy, Scan, Fax, PC Fax, Print/Scan To USB |
| Embedded Web Server Remote Ui | Yes |
| Web Browser Support For Remote Ui | Microsoft Internet Explore 7.0 Or Higher, Safari 3.2.1 Or Higher |
| Print Protocols | LPD, RAW, WSD-Print (IPv4,IPv6) |
| Tcp Ip Set Of Application Services | DHCP, BOOTP, RARP, Auto IP, Bonjour(MDNS), DHCPv6 (IPv6), HTTP, HTTPS, POP Before SMTP (IPv4,IPv6), ARP+PING, WINS (IPv4) |
| Network Management Protocols | SNMPv1, SNMPv3 (IPv4,IPv6) |
| Os Compatibility | Windows® 8, Windows 7, Windows Server® 2012, Windows Server 2008 R2, Windows Server 2008, Windows Vista®, Windows Server 2003, Windows® XP, Mac® OS X 10.5.8 & Up, Linux(Print Only) |
| Cable Included | Power Cord (USB Not Included) |
| Bundled Software | Printer Driver, Fax Driver, Scanner Driver, Network Scan Utility, MF Toolbox, Presto! PageManager |
| Power Consumption | Max: Approx. 1,200W During Operation: Approx. 450W Standby: Approx. 23W Energy Saver: Approx. 1W |
| Typical Energy Consumption | 0.9kWh |
| Dimensions | 17" (W) X 19.1" (D) X 18.9" (H) |
| Unit Weight Without With Cartridge | 63.1 Lbs. (W/O Cartridge) 68.3 Lbs. (W/Cartridge) |
| Package Weight | Approx. 81 Lbs. |
| Cartridge Type | Cartridge 118 Black (Yields Approximately 3,400 Pages) Cartridge 118 YMC (Yields Approximately 2,900 Pages) *Yields Based On ISO/IEC Standard |
| Lcd Display | 7-Line QVGA Color LCD |
| Duty Cycle | Up To 40,000 Pages Per Month |
| Department Id Management | Yes, Up To 300 ID's |
| Security | Native Secured Print, IEEE802.1x, SNMPv3, HTTPS, IPSEC |
| Languages | English, French, Spanish, Portuguese |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
