Color imageCLASS MF8280Cw
- Color imageCLASS MF8280CW product
- Setup Instructions
- Power Cord
- Telephone Cable
- Registration Card
- Starter Cartridge 131
- Manuals
- User Software CD-ROM
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The Canon Color imageCLASS MF8280Cw will simplify workflow and keep up with your mobile life.
The imageCLASS MF8280Cw has 4-in-1 capabilities – you can print, copy, scan and fax all from the same machine. The MF8280Cw is also equipped with an array of mobile capabilities, easy-to-use features and superior imaging technologies.
With mobility being a prominent part of today's workforce the MF8280Cw brings multiple solutions to the table. The MF8280Cw is compatible with the free Canon Mobile Printing8 app which allows users to print directly from their iPhone® or iPad®. Users can print a wide range of document types and have the ability to choose different finishing options. Additionally, the MF8280Cw is compatible with Google Cloud Print™9, allowing you to print documents on the go. The Direct Print feature provides the ability to plug in a USB and print your documents without even needing a PC.
In order to keep productivity an important part of your daily life the MF8280Cw features multiple easy to use options and simple supply replenishment. The 7-line color LCD display allows users to navigate seamlessly through the menu. You can also access scanning and eco-copy functions directly from the control panel with the Simple Solution Keys. With the front-loading 150-sheet paper cassette6 you can re-fill paper with ease. The cartridges can also be accessed in the front of the machine, with the Single Cartridge System you will only have one unit to replace when each toner runs out. The 50-sheet automatic document feeder allows users to feed multiple pages at a time, instead of just one, which can help to save time when scanning and copying.
Canon's Superior Imaging Technologies that are incorporated into the MF8280Cw provide brilliant, crisp output . With a print quality of 1200 x 1200 dpi you can ensure your office will experience the quality it deserves. These documents are printed in both color and black and white at speeds of up to 14 pages per minute1 with a quick first print time of 18 seconds or less2.
Wireless Connectivity - print from almost anywhere in your home or office
Easily access the scan and eco-copy functions right from the control panel with the Simple Solution Keys
Navigate through all the features seamlessly with the 7-line color LCD display
Print black and white and color at up to 14 pages per minute
Easily scan to, or print documents directly from, your USB flash drive
Copy, scan, and fax without having to worry about feeding originals one at a time with the 50-sheet Automatic Document Feeder
Google Cloud Print™ Ready for printing on the go
Print a variety of file types from your iPhone® or iPad® with the free Canon Mobile Printing app
Enjoy easy paper handling with the 150-sheet front-loading cassette and 1-sheet multipurpose tray
Print documents, web pages, emails and photos from your iPad, iPhone and iPod touch using Apple Air Print™
- Print speed is based on internal testing. Print speed may vary depending on the number of copies selected, as well as on the settings for size, type and orientation of paper.
- May vary depending on the output environment.
- Letter size, after being restored from energy saver mode.
- The Public Switched Telephone Network currently supports fax modem speeds of 28.8 Kbps or lower, depending on telephone line conditions. Sending and receiving fax machines need to conform to ITU-T v.34 guidelines.
- Based on ITU-T #1 Chart (standard mode).
- Based on 20 lb. bond paper.
- Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
- Requires Canon Mobile Printing app available free on the App store. Compatible with iPhone 5, iPhone 4S, iPhone 4, the new iPad, iPad 2, and the original iPad running OS 5.1 - 6.0.
- Requires an Internet connection and Google Account. Printer firmware update may be necessary for Google Cloud Print™ function. Certain exceptions may apply. A PC running Windows XP or later or A Mac running OS 10.4.11 or later and USB cable required to perform firmware update
- AirPrint™ functionality requires an iPad, iPad Mini, iPad 2, the new iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint™-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base Station, or Time Capsule is not supported.
| Printer Type | Color Laser |
| Print Speed | Up To 14ppm (1-Sided Plain Paper Letter)1 |
| First Print Time | 18 Seconds Or Less (Letter)2 |
| Printer Language | UFR II LT (Host-Based) |
| Print Resolution | Up To 1200 X 1200 Dpi (2400 X 600 Dpi Quality) |
| Maximum Print Size | Up To Legal |
| Print Modes | Watermark, Toner Save, Page Composer, Poster |
| Print Memory | 256 MB (Shared) |
| Copy Type | Color Laser |
| Copy Speed | Up To 14cpm (Letter) |
| Copy Resolution | Up To 600 X 600 Dpi |
| Original Type | Text/Photo/Map |
| Halftones | 256 Levels |
| Warm Up Time | Approximately 23 Seconds |
| First Copy Time | Approximately 19 Seconds3 |
| Recovery Time | Approximately 8 Seconds |
| Maximum Number Of Copies | 99 Copies |
| Reduction Enlargement | 25 - 400% In 1% Increments |
| Zoom | 25 - 400% In 1% Increments |
| Copy Size | Platen: Up To Letter ADF: 5.5" X 5" To Legal |
| Copy Features | Collate 2 On 1 4 On 1 ID Card Copy Frame Erase |
| Copy Memory | 256 MB (Shared) |
| Modem Speed | Up To 33.6 Kbps (Super G3)4 |
| Fax Resolution | Up To 406 X 391 Dpi (Ultra Fine) |
| Transmission Time | JBIG (Approx. 3 Seconds) |
| Memory Capacity | Up To 512 Sheets5 |
| Speed Dials | 19 One-Touch Speed Dials 181 Coded Dials |
| Group Dialing | 199 Destinations |
| Sequential Broadcasting | 210 Destinations |
| Receive Modes | FAX Only, Manual, Answering, Fax/Tel Auto Switch |
| Fax Features | Remote RX, Dual Access, Distinctive Ring Pattern Detection, Error Correction Mode, Auto Redial |
| Activity Reports | Activity Result & Activity Management |
| Pc Fax | Sending Only |
| Fax Forwarding | (FAX -> FAX) |
| Scan Type | Color Contact Image Sensor (CIS) |
| Color Depth | 24-Bit |
| Scan Resolution | Up To 600 X 600 Dpi (Optical) 9600 X 9600 (Interpolated) |
| Scan Size | Platen: Up To Letter ADF: 5.5" X 5" To Legal |
| Compatibility | TWAIN, WIA |
| Output File Formats | PDF(Compact), PDF, JPEG, TIFF |
| Scan Features | Scan To USB |
| Pull Scan | USB And Network |
| Push Scan Scan To Pc | USB And Network |
| Standard Paper Source | 150-Sheet Cassette Plus 1-Sheet Multipurpose Tray6 |
| Document Feeder | 50-Sheet Simplex6 |
| Paper Output | 125 Sheets (Face Down) |
| Paper Weight | 16-58 Lb. Bond (Cassette) 16-58 Lb. Bond (Multipurpose Tray) |
| Media Sizes | Letter, Legal, A4, A5, B5, B6, Statement, Executive |
| Media Types | Plain Paper, Heavy Paper, Recycled, Transparency, Label, Envelope, Index |
| Envelope Capacity | 10 Envelopes (Cassette) , 1 Envelope (Multipurpose Tray) |
| Envelope Types | Com 10, Monarch, DL, C5, B5 |
| Standard Interface | USB Device 2.0 Hi-Speed, 10/100 Base-T Ethernet, 802.11 B/G/N Wireless7 |
| Wifi Access Mode | Infrastructure Mode |
| Wifi Authentication Methods | Open System, Shared Key, WPA-PSK, WPA2-PSK |
| Wifi Encryption Modes | WEP (64/128 Bit), TKIP, AES |
| Wps Easy Setup Support Methods | Push-Button Mode, PIN Code Mode |
| Mobile Functions | Canon Mobile Printing9, Google Cloud Print™10, Apple AirPrint™11 |
| Network Functions | Print, Copy, Scan, Fax, PC Fax, Print/Scan To USB |
| Embedded Web Server Remote Ui | Yes |
| Web Browser Support For Remote Ui | Microsoft Internet Explore 7.0 Or Higher, Safari 3.2.1 Or Higher |
| Print Protocols | LPD, RAW, WSD-Print (IPv6) |
| Tcp Ip Set Of Application Services | DHCP, BOOTP, RARP, Auto IP, Bonjour(MDNS), DHCPv6 (IPv6), HTTP, HTTPS, POP Before SMTP (IPv4,IPv6), ARP+PING, WINS (IPv4) |
| Network Management Protocols | SNMPv1, SNMPv3 (IPv4,IPv6) |
| Os Compatibility | Windows® 8, Windows 7, Windows Server® 2012, Windows Server 2008 R2, Windows Server 2008, Windows Vista®, Windows Server 2003, Windows® XP, Mac® OS X 10.5.8 & Up, Linux (Print Only) |
| Cable Included | Power Cord (USB Not Included) |
| Bundled Software | Printer Driver, Fax Driver, Scanner Driver, MF Toolbox, Presto! PageManager |
| Power Consumption | Max: Approx. 900W During Operation: Approx. 400W Standby: Approx. 23W Energy Saver: Approx. 2W |
| Typical Energy Consumption | 0.4kWh |
| Dimensions | 17" (W) X 19.1"(D) X 16.9"(H) |
| Unit Weight Without With Cartridge | 52 Lbs. (W/O Cartridge) 57.3 Lbs. (W/Cartridge) |
| Package Weight | Approx. 67.2 Lbs. |
| Cartridge Type | Cartridge 131 Black (Yields Approximately 1,400 Pages) Cartridge 131 YMC (Yields Approximately 1,500 Pages) Cartridge 131 H Black (Yields Approximately 2,400 Pages) *Yields Based On ISO/IEC Standard |
| Lcd Display | 7-Line QVGA Color LCD |
| Duty Cycle | Up To 30,000 Pages Per Month |
| Department Id Management | Yes, Up To 300 ID's |
| Security | IEEE802.1x, SNMPv3, HTTPS, IPSEC |
| Languages | English, French, Spanish, Portuguese |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
