Color imageCLASS MF8080Cw
Designed for ease-of-use in your home or small office, the Canon color imageCLASS MF8080Cw gives you access to sophisticated features and high-performance technology in one compact and affordable solution.
- MF8080Cw
- Setup Instructions
- Power Cord
- Registration Card
- Starter Cartridges 116
- Manuals
- User Software CD-ROM
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Print, Copy, Fax and Scan with the Canon Color imageCLASS MF8080Cw Wireless Multifunction Printer.
The MF8080Cw delivers fast and accurate printing. Documents are ready in a short time, at print speeds up to 8 pages-per-minute (ppm) in color and 12 ppm in black and white.
Built-in WiFi capabilities allow you to access the best of your device’s resources from any location in your home or small office6. One Touch Button support gives you instant access to key functions such as Easy Scanning and Paper Save Copying (2-in-1 combination), helping you save time and increase office efficiency. The smart paper handling of the MF8080Cw includes a 150-sheet cassette, 1-sheet multipurpose tray, and a 50-sheet document feeder for your convenience4. Connect your USB removable media to the USB port located conveniently in the front of the machine to print or scan your letter, statement, or legal-sized documents.
The Superior Color Imaging Technology featured in the MF8080Cw captures fine details with remarkable tone-on-tone clarity, helping images stay true to the original. Canon Pure Black Technology ensures the richest blacks by utilizing only the black toner instead of traditional methods of combining toner colors.
For added flexibility and user-convenience, the Color imageCLASS MF8080Cw is equipped with unique features, such as: ID Card Copy, Auto Fax Forwarding, and Department ID Management which enables you to set limits on who can use the machine and how much they can print, copy or scan. The MF8080Cw uses approximately 3 watts of energy during Energy Saving Mode and meets Energy Star guidelines, saving you money on energy costs.
Like many imageCLASS products, the MF8080Cw is part of the Generation Green program, Canon's initiative to reduce environmental burdens in all stages of a product's life-cycle.
Print and copy at up to 8 ppm in color, and at up to 12 ppm in black & white
Quick First Print provides first print time of approximately 22 seconds in black & white and 28 seconds in color
WiFi Capabilities: Print, Scan and PC Fax at up to 802.11n speed
Scan in color up to 9600 dpi quality (interpolated) with up to 600 dpi optical resolution
Scan to USB for documents on the go
150-sheet cassette plus 1-sheet multipurpose tray
Up to 50-sheet ADF (Automatic Document Feeder)
33.6 Kbps Super G3 fax
Remote device management through embedded web server
USB 2.0 Hi-Speed for optimal performance
Efficient energy-saving mode; approximately 2.1W (wired), 2.5W (wireless) of energy used
User-friendly 5-line LCD for easy navigation
Password-protected Department ID Management helps to control device usage
Single Cartridge System for cost-efficient supplies replenishment
2. Combined with Toolbox feature.
3. PNG support MAC OS only.
4. Based on 20 lb. paper.
5. Warranty program is subject to certain conditions and restrictions. See the warranty card for details.
6. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
| Printing Method | Color Laser |
| Print Speed Choice | Black |
| Print Speed Text | 12 Ppm Monochrome (Letter) |
| Print Speed Choice | Color |
| Print Speed Text | Up To 8 Ppm (Letter) |
| Resolution Text | Up To 600 X 600 Dpi 2400 X 600 Dpi Quality |
| Toner Compatibility | Cartridge 116 (Yields: 1,500 CMY/2,300 Black Pages*) Maximum Monthly Duty Cycle: 30,000 Pages *Yield Is Based On ISO/IEC Standard |
| Print Features | Printer Language Canon UFR II LT (Host-Based) Print Modes Poster, Booklet, Watermark, Toner Saver, Page Composer Print Memory 128MB (Shared) |
| Paper Weights | 16 To 43 Lbs. Bond (Cassette) 16 To 58 Lbs. Bond (Multipurpose Tray) |
| Output Tray Capacity | 125 Sheets (Facedown) |
| Mono Copy Resolution | Up To 600 X 600 Dpi |
| Mono Copy Speed Up To | Black: Up To 12 Cpm (Letter) Color: Up To 8 Cpm (Letter) |
| Type | Color Laser |
| Zoom | 25-400% In 1% Increments |
| Halftones | 256 Levels |
| First Copy Time | Black/Color: Approx. 22.5 Seconds/28.6 Seconds (Letter) |
| Reductions Enlargement | 25%, 50%, 64%, 78% >129%, 200%, 400% |
| Document Feeder | 50-Sheet4 |
| Copy Size | Platen: Up To Letter ADF: 5.5" X 5" To Legal |
| Copy Feature | Frame Erase Memory Sort 2 On 1 4 On 1 ID Card Copy |
| Scanner Type | Color Contact Image Sensor (CIS) |
| Max Resolution Text | Up To 600 X 600 Dpi (Optical) Up To 9600 X 9600 Dpi (Interpolated)2 |
| Scanner Features | Rotate, Push Scan, Pull Scan |
| Color Depth | 24-Bit |
| Max Document Size | Platen: Up To Letter ADF: 5.5" X 5" To Legal |
| File Format | Hi-Compression PDF, Searchable PDF, PDF, JPEG, TIFF, BMP, PNG3 |
| Compatibility | TWAIN, WIA |
| Modem Speed | Up To 33.6 Kbps (Super G3) |
| Transmission Speed Approx | JBIG (2.6 Seconds) |
| Fax Resolution | Up To 406 X 391 Dpi (Ultra Fine) |
| Memory Capacity | Up To 512 Pages1 |
| Speed Dialing | 19 Favorite Dials 181 Coded Dials |
| Group Dialing | Group Dialing: 199 Destinations |
| Receive Options | Fax Only, Manual, Answering, Fax/Tel Auto Switch |
| Fax Features | Remote RX, Dual Access, Distinctive Ring Pattern Detection, Error Correction Mode, Auto Redial, Fax Activity Reports |
| Other Features Networking | PC Fax (Sending Only) Fax Forwarding Memory Backup (5 Minutes) |
| Os Compatibility | Windows&Reg; 8, Windows&Reg; 7, Windows Server&Reg; 2008 (R1/R2), Windows Vista&Reg;, Windows Server 2003, Windows XP/2000, Mac&Reg; OS X 10.4.9 & Up |
| Standard Interface | USB Device 2.0 Hi-Speed 10/100 Base-T Ethernet (Network) IEEE 802.11 B/G/N |
| Software Included | Canon Drivers, MF Toolbox, Document Management & OCR Software |
| Power Source | 120V-127V, 60Hz 220V-240V, 50/60Hz |
| Power Consumption Approx | Max: 900W Energy Saver: 3W (Wired) / 4W (Wireless) Standby: 15W |
| Dimension W X D X H | 17.0" (W) X 19.2" (D) X 16.9" (H) |
| Weight | Approx. 52.0 Lbs. (W/O Cartridge) Approx. 57.4 Lbs. (W/ Cartridge) |
| Operating Temperature | 50F - 86F |
| Operating Humidity | 20%-80% RH (No Condensation) |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
