Color imageCLASS MF746Cdw
- imageCLASS Color MF746Cdw product
- Cartridge 055 CMY: Starter 1,200 Yield / K: Standard 2,300 Yield
- Power Cord
- Telephone Cable
- Starter Guide
- User Software DVD-ROM
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Designed for small work groups, the Canon Color imageCLASS MF746Cdw offers feature-rich capabilities with high-quality imaging and minimal maintenance. Print, copy, scan, and fax capabilities help you accomplish necessary tasks with just one machine. A 5" color touchscreen delivers an intuitive user experience and can be customized by a device administrator to simplify many daily tasks.
The Color imageCLASS MF746Cdw is registered EPEAT Silver.
Usability
- 5" intuitive color touchscreen with smartphone-like usability.
- A unique, customized device experience with Application Library.
- Supports certain compatible mobile solutions for printing and scanning.1
- Scan and convert documents to searchable digital files through a single-pass, duplex document feeder.
- Designed for smaller print jobs with first print-out time as fast as 7.5 seconds.
Security Features
- Helps mitigate risk of confidential information loss, as documents are only stored in short-term memory.
- Security settings can be set behind an administrator log-in. When used in conjunction with imageWARE Enterprise Management Console Device Configuration Manager Plug-in, these settings can be captured and exported to other devices on the same network.2
- Remotely control device access and set rules via optional uniFLOW software.
- Limit document distribution by implementing Send-to-Myself-only.
Cost Management
- Leverage optional uniFLOW software for full accounting and reporting for Canon and third-party devices, pull printing, and job routing.
- Service parts are designed for the machine's life cycle to help minimize need for proactive maintenance and helps reduce service calls.
- High-capacity, all-in-one cartridge helps reduce overall supply costs.
Device and Fleet Management
- Designed for quick, easy deployment.
- Remote diagnostics for rapid service response.
- Easily monitor device status and consumable levels, observe meter readings, manage settings, and implement security settings.
Quality and Reliability
- Canon's signature reliability and engine technologies keep productivity high and minimize the impact on support resources.
- Designed to achieve maximum uptime with status notifications to help keep supplies replenished.
- Intuitive animations for common tasks like consumables replacement.
Sustainability
- A combination of fusing technologies and low-melting-point toner minimizes power requirements and therefore uses less energy.
- Encourages environmentally conscious work practices by enabling multiple settings that can help save paper and energy.
- ENERGY STAR® certified and rated EPEAT® Silver.3
Manage Output with uniFLOW Software
Fleet Management Tools
Fast, Single-Pass Duplex Scanning
Easy to Use with Application Library
- Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit www.cla.canon.com/cla/en/office/MobileApps.
- Please reference user manuals for details on settings available to export.
- For current EPEAT ratings (Gold/Silver/Bronze), please visit www.cla.canon.com/cla/en/epeat.
- Includes consumables.
- Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
| Printer Type | Color Laser Multifunctional |
| Print Speed | Up To 28 Ppm (Letter); Up To 22.9 Ppm (Legal) 5 |
| First Print Time | Approx. 7.5 Seconds |
| Printer Language | UFR II, PCL®6, PCL®5, Adobe PostScript® 3™ |
| Print Resolution | 600 X 600 (Dpi) |
| Maximum Print Size | Cassettes: Letter, Legal, Statement, Executive, Envelope: COM10, Monarch, C5, DL, Custom (Min. 3" X 5" To Max. 8.5" X 14") Stack Bypass: Letter, Legal, Statement, Executive Envelope: COM10, Monarch, C5, DL Custom (Min. 3" X 5" To Max. 8.5" X 14") |
| Duplex Print | Automatic (Standard) |
| Print Memory | 1 GB |
| Copy Speed | Up To 28 Ppm (Letter); Up To 22.9 Ppm (Legal) |
| Copy Resolution | 600 X 600 (Dpi) |
| First Copy Time | Platen: 11.2 Seconds/13.1 Seconds (BW/Color) ADF: 9.9 Seconds/11.8 Seconds (BW/Color) |
| Reduction Enlargement | Magnifications: 25% - 400% (1% Increments) Preset Reductions: 25%, 50%, 64%, 78% Preset Enlargements: 129%, 200%, 400% |
| Copy Size | Platen: Up To Letter ADF: Up To Legal |
| Modem Speed | Super G3: 33.6 Kbps G3: 14.4 Kbps |
| Fax Resolution | 400 X 400, 200 X 400, 200 X 200, 200 X 100 (Dpi) |
| Memory Capacity | Up To 512 Pages |
| Speed Dials | Max. 281 |
| Group Dialing | Max. 299 Dials |
| Sequential Broadcasting | Max. 310 Addresses |
| Fax Features | RX Mode, Resolution, Two-Sided Original, Density, Sharpness, Favorite Settings, Duplex Fax |
| Scan Type | Single-Pass Duplexing Automatic Document Feeder |
| Scan Resolution | Push Scan: Up To 300 X 600 Pull Scan: Up To 600 X 600 |
| Scan Size | Platen: Sheet, Book Document Feeder: Legal, Letter, Statement |
| Duplex Scan | Yes |
| Compatibility | ScanGear MF For TWAIN, And WIA |
| Output File Formats | Standard: TIFF, JPEG, PDF (Compact, Searchable) Optional: PDF (Encrypted, Digital Signature) |
| Standard Paper Source | Standard: 250-Sheet Paper Cassette, 50-Sheet Stack Bypass |
| Optional Paper Source | Optional: 550-Sheet Paper Cassette (Cassette Unit AF-1) |
| Paper Output | Standard: 75 Sheets |
| Paper Weight | Cassette: 16 Lb. Bond To 53 Lb. Bond ( 60 To 200 G/M2) Stack Bypass: 16 Lb. Bond To 53 Lb. Bond ( 60 To 200 G/M2) |
| Media Sizes | Cassettes: Letter, Legal, Statement, Executive, Envelope: COM10, Monarch, C5, DL, Custom (Min. 3" X 5" To Max. 8.5" X 14") Stack Bypass: Letter, Legal, Statement, Executive Envelope: COM10, Monarch, C5, DL Custom (Min. 3" X 5" To Max. 8.5" X 14") |
| Media Types | Cassettes: Thin, Plain, Recycled, Color, Thick, Coated, Label, Letter, Envelope (10 Envelopes) Stack Bypass: Thin, Plain, Recycled, Color, Thick, Coated, Label, Letter, Envelope (1 Envelope) |
| Standard Interface | USB 2.0 X2 (Host), USB 2.0 X1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/G/N, Wi-Fi® Direct Connection, Near Field Communication |
| Wifi Authentication Methods | Wi-Fi Infrastructure Mode: WEP 64/128 Bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES) Wi-Fi Access Point: WPA2-PSK (AES) |
| Mobile Functions | Apple® AirPrint,® Canon PRINT Business1, Mopria™ Print Service, Google Cloud Print™6 |
| Network Management Protocols | IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X(Wired Only), IPv6, SMTP Authentication, POP Authentication, POP Authentication Before SMTP |
| Os Compatibility | Windows 7/Windows 8.1/Windows 10/Windows Server 2008/Windows Server 2008 R2/Windows Server 2012/ Windows Server 2012 R2/Windows Server 2016 / Mac OS X V10.9.5 (Or Later) |
| Power Consumption | Maximum: Approx. 1470 W Standby: Approx. 20.5 W Sleep Mode: Approx. 0.6 W |
| Typical Energy Consumption | 1.0 KWh Power Requirements: AC 120-127 V:6.5 A, 60 Hz Standards: ENERGY STAR® Qualified, Rated EPEAT Silver 3 Operating Environment: Temperature: 50 To 86° F Humidity: 20 To 80% RH (No Condensation) |
| Dimensions | Standard (Desktop): 18.8" X 18.8" X 18.4" (478 Mm X 478 Mm X 467 Mm ) Box: 24.0" X 23.0" X 23.2" (610 Mm X 584 Mm X 589 Mm) |
| Unit Weight Without With Cartridge | Approx. 64 Lb. (29 Kg) Without Cartridge |
| Package Weight | Approx. 76 Lb. (35 Kg)4 |
| Lcd Display | 5" Color Touch Panel |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
