Color imageCLASS MF735Cx
- Color imageCLASS MF735Cdw Product
- Cartridge 046 CMY: Starter 1,200 Yield / K: Standard 2,200 Yield (ISO / IEC Standard)
- Power Cord
- Starter Guide
- User Software DVD-ROM
- Telephone Cable
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
2. May vary depending on the output environment.
3. Letter size, after being restored from energy saver mode.
4. The Public Switched Telephone Network currently supports fax modem speeds of 28.8 Kbps or lower, depending on telephone line conditions. Sending and receiving fax machines need to conform to ITU-T v.34 guidelines.
5. Based on ITU-T #1 Chart (standard mode).
6. Based on 20 lb. bond paper.
7. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
8. Requires an Android mobile device with NFC hardware running Android 4.0 or later, and the Canon Print Business app, available for free at Google Play. Canon Print Business app must be open to use tap and print functionality.
9. Wi-Fi®; is a registered trademark of the Wi-Fi Alliance®;. The Wi-Fi CERTIFIED™ Logo is a certification mark of the Wi-Fi Alliance®;.
10. Canon PRINT Business is a free app available on the App Store®; and Google Play™ Store. Users of Canon Mobile Printing can simply update the app to use Canon PRINT Business. Users who have installed Canon Mobile Scanning for Business should install Canon PRINT Business on their compatible device. After Canon PRINT Business is installed, users can re-register their Canon Mobile Scanning for Business device list and local documents. Android is a trademark of Google Inc. App Store is a service mark of Apple Inc. iPhone, iPad Air, iPad, iPad mini, are trademarks of Apple Inc., registered in the U.S. and other countries. iOS is a trademark or registered trademark of Cisco in the United States and other countries and is used under license.
11. AirPrint functionality requires an iPad, iPad Mini, iPad 2, the new iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base Station, or Time Capsule is not supported.
12. Mopria Print Service, available for free at the Google Play Store, requires a compatible Android KitKat 4.4 smartphone or tablet. The printer must be either wirelessly connected to the network router or with an Ethernet cable. The mobile device and printer must be connected to the same network.
13. Google Cloud Print requires an Internet connection and Google Account. Printer firmware update may be necessary for Google Cloud Print™ function. Certain exceptions may apply. A PC running Windows XP or later or a Mac running OS 10.4.11 or later and USB cable are required to perform firmware update.
| Printer Type | All In One, Color, Wireless, Duplex Laser Printer |
| Print Speed | Up To 28 Ppm (1-Sided Plain Paper Letter), Up To 23ppm (2-Sided Plain Paper Letter)1 (Bw / Color) |
| First Print Time | 9 Seconds Or Less (Letter)2 |
| Printer Language | UFR II (Host Based), PCL (6, 5c), Adobe® Postscript® |
| Print Resolution | Up To 600 X 600 Dpi, 1200 X 1200 Dpi Equivalent |
| Maximum Print Size | Up To Legal |
| Duplex Print | Yes |
| Print Modes | Poster, Booklet, Watermark, Toner Saver, Page Composer |
| Print Memory | 1 GB (Shared) |
| Direct Print From Usb | JPEG, TIFF, PDF |
| Copy Type | Color Laser |
| Copy Speed | Up To 28ppm (Letter) |
| Duplex Copy Speed | Up To 23cpm (Letter) |
| Copy Resolution | Up To 600 X 600 Dpi |
| Original Type | Text/Photo, Text, Photo |
| Halftones | 256 Levels |
| Warm Up Time | 13 Seconds Or Less From Power On |
| First Copy Time | Approximately 10 / 11 Seconds Or Less (Bw/Color, Letter)3 |
| Recovery Time | Approximately 6 Seconds |
| Maximum Number Of Copies | Up To 999 Copies |
| Reduction Enlargement | 25 - 400% In 1% Increments |
| Copy Size | Platen: Up To Letter / DADF: Up To Legal |
| Copy Features | Frame Erase, Memory Sort, 2 On 1, 4 On 1, ID Card Copy |
| Copy Memory | 1 GB (Shared) |
| Modem Speed | Up To 33.6 Kbps (Super G3)4 |
| Fax Resolution | Up To 406 X 391 (Ultrafine) |
| Transmission Time | Approx. 3 Seconds |
| Memory Capacity | Up To 512 Sheets5 |
| Speed Dials | 19 One-Touch Speed Dials, Up To 281 Coded Dials |
| Group Dialing | 199 Destinations |
| Sequential Broadcasting | 310 Destinations |
| Duplex Fax | Yes |
| Receive Modes | FAX Only, Manual, Answering, Fax/Tel Auto Switch |
| Fax Features | Fax Forwarding, Dual Access, Remote Reception, PC Fax (TX Only), Distinctive Ring Pattern Detection, Error Detection Mode, Auto Redial, Fax Activity / Activity Result Reports, Fax Activity Management Reports |
| Memory Backup | Permanent Fax Memory Backup (Backup With Flash Memory) |
| Scan Type | Color Contact Image Sensor (CIS) |
| Color Depth | 24-Bit |
| Scan Resolution | Up To 600 X 600 Dpi (Optical), 9600 X 9600 Dpi (Software Interpolated Resolution) |
| Scan Size | Platen: Up To Letter / ADF: Up To To Legal |
| Duplex Scan | Yes (One Pass Duplex Scan) |
| Compatibility | TWAIN, WIA 2.0, ICA |
| Output File Formats | JPEG, TIFF, PDF, Compact PDF, PDF (OCR) |
| Scan Features | Push Scan, Pull Scan, Scan To USB |
| Pull Scan | USB And Network |
| Push Scan Scan To Pc | USB And Network |
| Standard Paper Source | 250-Sheet Cassette Plus 50-Sheet Multipurpose Tray6 |
| Optional Paper Source | 550-Sheet Cassette6 |
| Document Feeder | 50-Sheet Duplex6 |
| Paper Output | 150 Sheets (Face Down) |
| Paper Weight | 16-73 Lb. Bond (Cassette/Optional Cassette/Multipurpose Tray) |
| Media Sizes | Letter, Legal, A4, A5, B5, Statement, Executive |
| Media Types | Plain / Heavy / Recycled / Color Paper, Label, Postcard, Envelope |
| Envelope Capacity | 5 Envelopes (Multipurpose Tray) |
| Envelope Types | Com 10, Monarch, DL, C5 |
| Standard Interface | USB Device 2.0 Hi-Speed, 10/100/1000 Base-T Ethernet (Network), Wi-Fi 802.11 B/G/N7, NFC (Near Field Communication)8 |
| Wifi Access Mode | Infrastructure Mode, WPS Easy Setup, Wi-Fi® Direct Connection9 |
| Wifi Authentication Methods | WEP 64/128 Bit, WPA-PSK (TKIP, AES), WPA2-PSK (AES), 802.1x (LEAP, EAP-FAST, PEAP, EAP-TLS, EAP-TTLS) |
| Wifi Encryption Modes | WEP (64/128 Bit), WPA-PSK (TKIP, AES), WPA2-PSK (AES) |
| Wps Easy Setup Support Methods | Push-Button Mode, PIN Code Mode |
| Mobile Functions | Canon PRINT Business10, Apple® AirPrint®11, Mopria™ Print Service12, Google Cloud Print™13 |
| Network Functions | Print, Scan (SMB, E-Mail, FTP), PC Fax |
| Embedded Web Server Remote Ui | IE 7.0 Or Higher, Safari 3.2.1 Or Higher |
| Print Protocols | LPD, RAW, WSD-Print (IPv4, IPv6) |
| Tcp Ip Set Of Application Services | Bonjour (MDNS), HTTP, HTTPS, POP Before SMTP (IPv4, IPv6), DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6) |
| Network Management Protocols | SNMPv1, SNMPv3 (IPv4, IPv6) |
| Os Compatibility | Windows® 10, 8.1, 8, 7, Windows Server® 2016, Windows Server® 2012, 2012 R2, 2008 R2, 2008, Windows Vista®, Mac OS 10.7.5 Or Later |
| Cable Included | Power Cord, Phone Cable (USB Not Included) |
| Bundled Software | Printer Driver, Fax Driver, Scanner Driver, Network Scan Utility, MF Scan Utility, AddressBookTool, Toner Status |
| Power Consumption | Approx: 520 W (During Operation), 20.6 W (Standby), Energy Saver Mode: .8 W (USB/Wired/Wireless)
| Typical Energy Consumption | 1.1kWh |
| Dimensions | 18.5 Inches (W) X 18.5 Inches (D) X 18.1 Inches (H) |
| Unit Weight Without With Cartridge | 54 Lbs. (W/O Cartridge), 58.4 Lbs. (W/Cartridge) |
| Package Weight | Approx. 74.8 Lbs. |
| Cartridge Type | Cartridge 046 (CMY Yields 2,300 Sheets / K Yields 2,200 Sheets, ISO/IEC Standard) And Cartridge 046 Hi Capacity CMYK (CMY Yields 5,000 Sheets / K Yields 6,300 Sheets, ISO/IEC Standard). Single Cartridge System *Yields Based On ISO/IEC Standard |
| Lcd Display | 5 Inch, Color Touch LCD |
| Duty Cycle | Up To 50,000 Pages Per Month |
| Department Id Management | Up To 300 IDs |
| Security | IP / MAC Address Filtering, SNMPv3, SSL (HTTPS/IPPS), IEEE802.1x |
| Languages | English, Japanese, French, Spanish, German, Italian, Portuguese, Chinese, Korean |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
