Color imageCLASS MF634Cx
- Color imageCLASS MF634Cdw Product
- Cartridge 045 CMY: Starter 700 Yield / K: Standard 1,400 Yield (ISO / IEC Standard)
- Power Cord
- Starter Guide
- User Software DVD-ROM
- Telephone Cable
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The all-in-one, Canon Color imageCLASS MF634Cdw offers feature rich capabilities in a high quality, reliable printer that is ideal for any office environment. Print, scan, copy and fax capabilities help you accomplish all necessary tasks with just one machine. Easy to use features such as the intuitive 5-inch color touch LCD panel, various mobile solutions and a single-pass, duplex scan feature, your business will have the support and efficiency it deserves.
Your professional quality color documents are printed at speeds of up to 19 pages per minute1 in both color and black and white with a quick first print time of 12 seconds or less2. Get high quality, crisp and bold color business documents as well as photos using V2 (Vivid and Vibrant) Color Technology, which increases image sharpness and color vibrancy. Eco-conscious, all-mode duplexing saves you time, paper, and related costs, as well as limits interruptions so you can print, scan, copy and fax with ease.
The intuitive 5-inch color touch LCD panel allows you to navigate through the menu seamlessly. The wide screen and color display is user friendly and easy to read. You can also customize the settings to access the features you use most.
The MF634Cdw has wireless connectivity, increasing your productivity and allowing you to print from almost anywhere in your home or office7. The device also has built in Wi-Fi® Direct Connection capability8, enabling easy connection to mobile devices without a router. Pairing your mobile device just got easier – simply scan the QR Code function on the MF634Cdw using the Canon PRINT Business app9 to connect wirelessly.
Enjoy a variety of easy to use mobile features for printing on the go using your compatible mobile device, such as Using the Canon PRINT Business9, Apple® AirPrint®10, Mopria™ Print Service11 and Google Cloud Print™12. Using the Canon PRINT Business9 app, you can also scan hardcopy originals.
Manage device usage and color access for up to 300 IDs, using password protected Department ID Management. USB Direct Print allows you to print from and scan to that USB in JPEG, TIFF and PDF formats. With ID Card Copy, you can easily create copies of identification cards or other small documents on a single page.
The MF634Cdw provides generous paper capacity to keep up with your fast paced business output needs. With the front-loading 150-sheet paper cassette, 50-sheet duplexing automatic document feeder, 1-sheet manual feed slot, your paper handling requirements are covered.6 The single-pass, duplex scan allows you to scans both sides of your document in a single pass through the duplex, automatic document feeder.
The MF634Cdw uses less than 1 W of energy (USB/wired/wireless) in Energy Saver Mode, helping you save money on energy costs. The Single Cartridge System combines the toner and drum into 1 unit, making replacement of cartridges simple. High-capacity toner options keep you printing longer, with limited toner replacements so you can keep pace with your busy output needs. The MF634Cdw uses Canon GENUINE Toner, Cartridge 045 CMYK (CMY yields 1,300 sheets / K yields 1,400 sheets, ISO/IEC standard) and Cartridge 045 Hi Capacity CMYK (CMY yields 2,200 sheets / K yields 2,800 sheets, ISO/IEC standard).
Print at speeds of up to 19 pages per minute, with your first print in your hands in 12 seconds or less.
Easily connect your mobile devices without a router using Wi-Fi® Direct Connection.
Single-pass, duplex scan—scans both sides of your document in a single pass.
V (Vivid and Vibrant) Color Technology produces high-quality prints by increasing image sharpness and color vibrancy.
Print on-the-go with Canon PRINT Business, Apple® AirPrint®, Mopria™ Print Service, and Google Cloud Print™.
QR Code Connection allows you to easily pair your mobile device using the Canon PRINT Business app.
Navigate through all the features with the user-friendly, 5-inch, Color, Touch LCD Panel.
Eco-conscious, two-sided printing out of the box saves paper and related cost.
Easily print from, and scan to, your USB flash drive in JPEG, TIFF, and PDF formats.
Low energy consumption; uses less than 1 W (USB/wired/wireless) in Energy Saver Mode.
Hi-Capacity Toner Options keep up with your printing needs and limit toner replacement interruptions.
2. May vary depending on the output environment.
3. Letter size, after being restored from energy saver mode.
4. The Public Switched Telephone Network currently supports fax modem speeds of 28.8 Kbps or lower, depending on telephone line conditions. Sending and receiving fax machines need to conform to ITU-T v.34 guidelines.
5. Based on ITU-T #1 Chart (standard mode).
6. Based on 20 lb. bond paper.
7. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
8. Wi-Fi®; is a registered trademark of the Wi-Fi Alliance®;. The Wi-Fi CERTIFIED™ Logo is a certification mark of the Wi-Fi Alliance®;.
9. Canon PRINT Business is a free app available on the App Store®; and Google Play™ Store. Users of Canon Mobile Printing can simply update the app to use Canon PRINT Business. Users who have installed Canon Mobile Scanning for Business should install Canon PRINT Business on their compatible device. After Canon PRINT Business is installed, users can re-register their Canon Mobile Scanning for Business device list and local documents. Android is a trademark of Google Inc. App Store is a service mark of Apple Inc. iPhone, iPad Air, iPad, iPad mini, are trademarks of Apple Inc., registered in the U.S. and other countries. iOS is a trademark or registered trademark of Cisco in the United States and other countries and is used under license.
10. AirPrint functionality requires an iPad, iPad Mini, iPad 2, the new iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base Station, or Time Capsule is not supported.
11. Mopria Print Service, available for free at the Google Play Store, requires a compatible Android KitKat 4.4 smartphone or tablet. The printer must be either wirelessly connected to the network router or with an Ethernet cable. The mobile device and printer must be connected to the same network.
12. Google Cloud Print requires an Internet connection and Google Account. Printer firmware update may be necessary for Google Cloud Print™ function. Certain exceptions may apply. A PC running Windows XP or later or a Mac running OS 10.4.11 or later and USB cable are required to perform firmware update.
Cartridge 045 Black
1,400 sheets, ISO / IEC Standard
Cartridge 045 Cyan
1,300 sheets, ISO / IEC Standard
Cartridge 045 Yellow
Cartridge 045 Magenta Hi-Capacity
Yields approx. 2,200 pages based on ISO/IEC Standard.
Cartridge 045 Black Hi-Capacity
Yields approx. 2,800 pages based on ISO/IEC Standard.
Cartridge 045 Cyan Hi-Capacity
Cartridge 045 Yellow Hi-Capacity
- Windows Server 2025
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS Sierra v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
Locating and installing your download Locating and installing your download ES Locating and installing your download PT
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
