Color imageCLASS LBP712Cx
- imageCLASS LBP712Cx Product
- Standard Cartridge 040 CMYK
- Power Cord
- Starter Guide
- User Software DVD-ROM
- Canon Drivers
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
2. May vary depending on the output environment.
3. Based on 20 lb. bond paper.
4. Canon PRINT Business is a free app available on the App Store®; and Google Play™ Store. For more information, including compatibility, please visit http://www.cla.canon.com/cla/en/office/MobileApps. Users of Canon Mobile Printing can simply update the app to use Canon PRINT Business. Users who have installed Canon Mobile Scanning for Business should install Canon PRINT Business on their compatible device. After Canon PRINT Business is installed, users can re-register their Canon Mobile Scanning for Business device list and local documents. Android is a trademark of Google Inc. App Store is a service mark of Apple Inc. iPhone, iPad Air, iPad, iPad mini, are trademarks of Apple Inc., registered in the U.S. and other countries. iOS is a trademark or registered trademark of Cisco in the United States and other countries and is used under license.
5. AirPrint functionality requires an iPad, iPad Mini, iPad 2, the new iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base Station, or Time Capsule is not supported.
6. Mopria Print Service, available for free at the Google Play Store, requires a compatible Android KitKat 4.4 smartphone or tablet. The printer must be either wirelessly connected to the network router or with an Ethernet cable. The mobile device and printer must be connected to the same network.
7. Google Cloud Print requires an Internet connection and Google Account. Printer firmware update may be necessary for Google Cloud Print™ function. Certain exceptions may apply. A PC running Windows XP or later or a Mac running OS 10.4.11 or later and USB cable are required to perform firmware update.
| Printer Type | Color Laser Single Function Printer |
| Print Speed | Up To 40 Ppm (Color/BW: 1 And 2-Sided, Plain Paper Letter)1 Up To 38 Ppm (Color/BW: 1 And 2-Sided, Plain Paper A4) |
| First Print Time | 6 Seconds Or Less (Letter)2 |
| Printer Language | UFR II, PCL 5c/E, PCL6, Adobe® PostScript® |
| Print Resolution | 600 X 600 Dpi, 9,600 Equivalent X 600 Dpi |
| Maximum Print Size | Up To Legal (Multipurpose Tray) |
| Duplex Print | Yes |
| Print Modes | Watermark, Page Composer, Toner Saver, Poster, Booklet, Collate |
| Print Memory | 1 GB |
| Direct Print From Usb | Print File Format: JPEG, TIFF, PDF, XPS |
| Standard Paper Source | Standard Cassette: 550-Sheet; 16 (7.2 Kg.) To 43 Lb. (19.5 Kg.) Bond (Plain Paper); Letter, A4, A5, B5, Statement, Executive (Min: 4 X 5.8 / Max: 8.5 X 11.7)3 Multipurpose Tray: 100-Sheet; 16 (7.2 Kg.) To 57 Lb. (25.8 Kg.) Bond (Plain Paper); Letter, Legal, A4, A5, B5, Statement, Executive (Min: 3 X 5 / Max: 8.5 X 14)3 |
| Optional Paper Source | 550-Sheet Cassette; 16 (7.2 Kg.) To 43 Lb.(19.5 Kg.) Bond (Plain Paper); Letter, Legal, A4, A5, B5, Statement, Executive (Min: 4 X 5.8 / Max: 8.5 X 14)3 |
| Document Feeder | NA |
| Paper Output | Approx. 200 Sheets (Face Down) |
| Media Types | Thin Paper, Plain Paper, Recycled Paper, Thick Paper, Colored Paper, Label, Post Card, Envelope, Rough Paper |
| Envelope Capacity | 10 |
| Envelope Types | Com 10, Monarch, C5, DL |
| Standard Interface | USB Device High-Speed 2.0, Shared 10/100/1000 BASE-T Ethernet (Network) |
| Usb Functions | |
| Mobile Functions | Canon PRINT Business4, Apple® AirPrint®5, Mopria™ Print Service6, Google Cloud Print™7 |
| Web Browser Support For Remote Ui | Microsoft Internet Explorer 7.0 Or Later |
| Supported Network Protocols | SNMPv1, SNMPv3 (IPv4,IPv6) |
| Tcp Ip Set Of Application Services | Bonjour(MDNS), HTTP, HTTPS, DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6), DDNS |
| Os Compatibility | Windows® 10, 8.1, 8, 7, Vista®, Windows Server® 2012 R2, 2012, 2008 R2, 2008, 2003 R2, 2003, Mac® OS10.6.8 & Up |
| Cable Included | Power Cord (USB Not Included) |
| Power Consumption | During Operation: 600 W Or Less, Standby: 34 W Or Less, Energy Saver: (120V) - 2.2 W Or Less (USB) / 1.2 W Or Less (Wired) (230V) - 2.4 W Or Less (USB) / 1.3 W Or Less (Wired) |
| Typical Energy Consumption | 1.4 Kwh (120V / 230V) |
| Dimensions | (W X D X H)*: 18.1" X 18.3" X 15.3" ( 458 Mm X 464 Mm X 388 Mm) |
| Unit Weight Without With Cartridge | 54.7 Lbs.(24.8 Kg.) (W/O Cartridge), 62.7 Lbs.(28 Kg.) (W/ Cartridges) |
| Package Weight | Approx. 77.2 Lbs.(35 Kg.) |
| Cartridge Type | Cartridge 040 Black (Yields Approximately 6,300 Pages), CMY (Yields Approximately 5,400 Pages) / Cartridge 040 Hi-Capacity Black (Yields Approximately 12,500 Pages), Hi-Capacity CMY (Yields Approximately 10,000 Pages) *Yields Based On ISO/IEC Standard |
| Lcd Display | 5 Line LCD Panel |
| Duty Cycle | Up To 80,000 Pages Per Month (RMPV (Recommended Monthly Print Volume): 1,000 - 7,000 Pages) |
| Security | SNMPv3, IP / MAC Address Filtering, HTTPS/IPPS, IEEE802.1x (Wired LAN) |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
