Color imageCLASS LBP712Cdn
- imageCLASS LBP712Cdn Product
- Standard Cartridge 040 CMYK
- Power Cord
- Starter Guide
- User Software DVD-ROM
- Canon Drivers
- Warranty Card
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The Canon Color imageCLASS LBP712Cdn is an easy to use, duplex, single function laser printer ideal for any business environment. The LBP712Cdn delivers lightning fast, exceptional color output and prints at speeds of up to 40 pages-per-minute1, with your first print available in 6 seconds or less2. The device supports UFR II, PCL 5c/e, PCL6 and Adobe® PostScript® printer languages, allowing greater versatility for your printing needs. Eco-friendly, automatic duplexing right out of the box helps your business save on paper and related costs. Designed to handle your versatile, growing and fast paced business output needs, the LBP712Cdn offers remarkable paper handling in an expandable, configurable construction. The LBP712Cdn comes standard with a 550-sheet cassette and 100-sheet multipurpose tray, with optional 550-sheet cassette available to support paper feeding up to 2,300 sheets3. The LBP712Cdn features mobile capabilities for printing on-the-go using your compatible mobile device such as Apple® AirPrint®5, Mopria™ Print Service6 and Google Cloud Print™7. The Canon PRINT Business4 app allows you to print to the device from compatible iOS or Android devices. With USB Direct Print, you can easily print from your USB Flash drive in JPEG, TIFF, PDF and XPS formats. The LBP712Cdn uses 2.2 watts of energy or less in energy saving mode, helping you save on energy costs. The single cartridge system combines the toner and drum into one unit, making replacement of cartridges simple. This printer uses GENUINE Canon Toner Cartridge 040 CMYK and 040 CMYK Hi-Capacity for higher volume printing.
Lightning fast, exceptional color laser output with print speed of up to 40 pages-per-minute, with your first print in your hands in 6 seconds or less.
Print on-the-go with Canon PRINT Business, Apple® AirPrint®, Mopria™ Print Service and Google Cloud Print™, using your compatible mobile device.
Remarkable paper handling in an expandable, configurable construction to support paper feeding up to 2,300 sheets.
Easily print from your USB Flash drive in JPEG, TIFF, PDF and XPS formats.
Supports UFR II, PCL 5c/e, PCL6 and Adobe® PostScript® printer languages, allowing greater versatility for your printing needs.
Energy Saver Mode uses less than 2.4 watts of energy, helping you save on energy costs.
Eco friendly, two-sided printing right out of the box helps your business save on paper and related costs.
2. May vary depending on the output environment.
3. Based on 20 lb. bond paper.
4. Canon PRINT Business is a free app available on the App Store®; and Google Play™ Store. For more information, including compatibility, please visit http://www.cla.canon.com/cla/en/office/MobileApps. Users of Canon Mobile Printing can simply update the app to use Canon PRINT Business. Users who have installed Canon Mobile Scanning for Business should install Canon PRINT Business on their compatible device. After Canon PRINT Business is installed, users can re-register their Canon Mobile Scanning for Business device list and local documents. Android is a trademark of Google Inc. App Store is a service mark of Apple Inc. iPhone, iPad Air, iPad, iPad mini, are trademarks of Apple Inc., registered in the U.S. and other countries. iOS is a trademark or registered trademark of Cisco in the United States and other countries and is used under license.
5. AirPrint functionality requires an iPad, iPad Mini, iPad 2, the new iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base Station, or Time Capsule is not supported.
6. Mopria Print Service, available for free at the Google Play Store, requires a compatible Android KitKat 4.4 smartphone or tablet. The printer must be either wirelessly connected to the network router or with an Ethernet cable. The mobile device and printer must be connected to the same network.
7. Google Cloud Print requires an Internet connection and Google Account. Printer firmware update may be necessary for Google Cloud Print™ function. Certain exceptions may apply. A PC running Windows XP or later or a Mac running OS 10.4.11 or later and USB cable are required to perform firmware update.
| Printer Type | Color Laser Single Function Printer |
| Print Speed | Up To 40 Ppm (Color/BW: 1 And 2-Sided, Plain Paper Letter)1 Up To 38 Ppm (Color/BW: 1 And 2-Sided, Plain Paper A4) |
| First Print Time | 6 Seconds Or Less (Letter)2 |
| Printer Language | UFR II, PCL 5c/E, PCL6, Adobe® PostScript® |
| Print Resolution | 600 X 600 Dpi, 9,600 Equivalent X 600 Dpi |
| Maximum Print Size | Up To Legal (Multipurpose Tray) |
| Duplex Print | Yes |
| Print Modes | Watermark, Page Composer, Toner Saver, Poster, Booklet, Collate |
| Print Memory | 1 GB |
| Direct Print From Usb | Print File Format: JPEG, TIFF, PDF, XPS |
| Standard Paper Source | Standard Cassette: 550-Sheet; 16 (7.2 Kg.) To 43 Lb. (19.5 Kg.) Bond (Plain Paper); Letter, A4, A5, B5, Statement, Executive (Min: 4 X 5.8 / Max: 8.5 X 11.7)3 Multipurpose Tray: 100-Sheet; 16 (7.2 Kg.) To 57 Lb. (25.8 Kg.) Bond (Plain Paper); Letter, Legal, A4, A5, B5, Statement, Executive (Min: 3 X 5 / Max: 8.5 X 14)3 |
| Optional Paper Source | 550-Sheet Cassette; 16 (7.2 Kg.) To 43 Lb.(19.5 Kg.) Bond (Plain Paper); Letter, Legal, A4, A5, B5, Statement, Executive (Min: 4 X 5.8 / Max: 8.5 X 14)3 |
| Document Feeder | NA |
| Paper Output | Approx. 200 Sheets (Face Down) |
| Media Types | Thin Paper, Plain Paper, Recycled Paper, Thick Paper, Colored Paper, Label, Post Card, Envelope, Rough Paper |
| Envelope Capacity | 10 |
| Envelope Types | Com 10, Monarch, C5, DL |
| Standard Interface | USB Device High-Speed 2.0, Shared 10/100/1000 BASE-T Ethernet (Network) |
| Usb Functions | |
| Mobile Functions | Canon PRINT Business4, Apple® AirPrint®5, Mopria™ Print Service6, Google Cloud Print™7 |
| Web Browser Support For Remote Ui | Microsoft Internet Explorer 7.0 Or Later |
| Supported Network Protocols | SNMPv1, SNMPv3 (IPv4,IPv6) |
| Tcp Ip Set Of Application Services | Bonjour(MDNS), HTTP, HTTPS, DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6), DDNS |
| Os Compatibility | Windows® 10, 8.1, 8, 7, Vista®, Windows Server® 2012 R2, 2012, 2008 R2, 2008, 2003 R2, 2003, Mac® OS10.6.8 & Up |
| Cable Included | Power Cord (USB Not Included) |
| Power Consumption | During Operation: 600 W Or Less, Standby: 34 W Or Less, Energy Saver: (120V) - 2.2 W Or Less (USB) / 1.2 W Or Less (Wired) (230V) - 2.4 W Or Less (USB) / 1.3 W Or Less (Wired) |
| Typical Energy Consumption | 1.4 Kwh (120V / 230V) |
| Dimensions | (W X D X H)*: 18.1" X 18.3" X 15.3" ( 458 Mm X 464 Mm X 388 Mm) |
| Unit Weight Without With Cartridge | 54.7 Lbs.(24.8 Kg.) (W/O Cartridge), 62.7 Lbs.(28 Kg.) (W/ Cartridges) |
| Package Weight | Approx. 77.2 Lbs.(35 Kg.) |
| Cartridge Type | Cartridge 040 Black (Yields Approximately 6,300 Pages), CMY (Yields Approximately 5,400 Pages) / Cartridge 040 Hi-Capacity Black (Yields Approximately 12,500 Pages), Hi-Capacity CMY (Yields Approximately 10,000 Pages) *Yields Based On ISO/IEC Standard |
| Lcd Display | 5 Line LCD Panel |
| Duty Cycle | Up To 80,000 Pages Per Month (RMPV (Recommended Monthly Print Volume): 1,000 - 7,000 Pages) |
| Security | SNMPv3, IP / MAC Address Filtering, HTTPS/IPPS, IEEE802.1x (Wired LAN) |
Waste Toner Box - WT-B1
Waste Toner Box WT-B1
Cartridge 040 Black
Yields approximately 6,300 sheets based on ISO / IEC standard.
Cartridge 040 Magenta
Yields approximately 5,400 sheets based on ISO / IEC standard.
Cartridge 040 Black Hi-Capacity
Yields approximately 12,500 sheets based on ISO / IEC standard.
Cartridge 040 Magenta Hi-Capacity
Yields approximately 10,000 sheets based on ISO / IEC standard.
Cartridge 040 Cyan
Cartridge 040 Yellow
Cartridge 040 Cyan Hi-Capacity
Cartridge 040 Yellow Hi-Capacity
Paper Feeder PF-D1
Paper Feeder PF-D1 supports up to 550-sheets, may use up to 3 cassettes with the LPB712Cdn
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
