Color imageCLASS LBP664Cdw
- imageCLASS Color LBP664Cdw product
- Cartridge 055 CMYK: Starter 1,200 Yield
- Power Cord
- Starter Guide
- User Software DVD-ROM
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The Color imageCLASS LBP664Cdw is registered EPEAT Silver.
Workflow Efficiency
- 5" intuitive color touchscreen with smartphone-like usability.
- A unique, customized device experience with Application Library.
- Supports various mobile printing solutions.1
- Designed for small print jobs with first-print time as fast as 7.5 seconds.
Security Features
- Helps mitigate risk of confidential information loss, as documents are only stored in short-term memory.
- Security settings can be set behind an administrator log-in. When used in conjunction with imageWARE Enterprise Management Console Device Configuration Manager Plug-in, these settings can be captured and exported to other devices on the same network.2
- Remotely control device access and set rules via optional uniFLOW software.
Cost Efficiency
- Leverage optional uniFLOW software for full accounting and reporting for Canon and third-party devices, pull printing, and job routing.
- Service parts are designed for machine's life cycle to help minimize need for proactive maintenance and helps reduce service calls.
- High-capacity, all-in-one cartridge helps reduce overall supply costs.
- Out-of-the-box, standard two-sided printing plus the ability to print multiple pages onto one sheet helps to reduce paper consumption.
Device and Fleet Management
- Designed for quick, easy deployment.
- Remote diagnostics for rapid service response.
- Easily monitor device status and consumable levels, observe meter readings, manage settings, and implement security settings.
Quality and Reliability
- Canon's signature reliability and engine technologies help keep productivity high and minimize the impact on support resources.
- Designed to achieve maximum uptime with status notifications to help keep supplies replenished.
- Intuitive maintenance videos for common tasks like consumables replacement.
Sustainability
- A combination of fusing technologies and low-melting-point toner minimizes power requirements and therefore uses less energy.
- Encourages environmentally conscious work practices by enabling multiple settings that can help save paper and energy.
- ENERGY STAR® certified and currently rated EPEAT® Silver.3
Manage Output with uniFLOW Software
Fleet Management Tools
Easy to Use with Application Library
- Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit www.cla.canon.com/cla/en/office/MobileApps.
- Please reference user manuals for details on settings available to export.
- For current EPEAT ratings (Gold/Silver/Bronze), please visit www.cla.canon.com/cla/en/epeat.
- Includes consumables.
- Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
- Subscription to a third-party cloud service required. Subject to third-party cloud service providers’ terms and conditions.
| Printer Type | Color Laser Single Function |
| Print Speed | Up To 28 Ppm (Letter); Up To 22.9 Ppm (Legal)5 |
| First Print Time | Approx. 7.5 Seconds |
| Printer Language | Ufr Ii, Pcl®6, Pcl®5, Adobe Postscript 3® |
| Print Resolution | 600 X 600 (Dpi) |
| Maximum Print Size | Cassettes: Letter, Legal, Statement, Executive Envelope: Com10, Monarch, C5, Dl Custom (Min. 3" X 5" To Max. 8.5" X 14") Manual Feed Slot: Letter, Legal, Statement, Executive Envelope: Com10, Monarch, C5, Dl Custom (Min. 3" X 5" To Max. 8.5" X 14") |
| Duplex Print | Automatic (Standard) |
| Print Memory | 1 Gb |
| Standard Paper Source | Standard: 250-Sheet Paper Cassette, 50-Sheet Stack Bypass |
| Optional Paper Source | Optional: 550-Sheet Paper Cassette (Cassette Unit Af-1) |
| Paper Output | Standard: 75 Sheets |
| Paper Weight | Cassette: 16 Lb. Bond To 53 Lb. Bond ( 60 To 200 G/M2) Manual Feed Slot: 16 Lb. Bond To 53 Lb. Bond ( 60 To 200 G/M2) |
| Media Sizes | Cassettes: Letter, Legal, Statement, Executive Envelope: Com10, Monarch, C5, Dl Custom (Min. 3" X 5" To Max. 8.5" X 14") Manual Feed Slot: Letter, Legal, Statement, Executive Envelope: Com10, Monarch, C5, Dl Custom (Min. 3" X 5" To Max. 8.5" X 14") |
| Media Types | Cassettes: Thin, Plain, Recycled, Color, Thick, Coated, Label, Letter, Envelopes (10 Envelopes) Manual Feed Slot: Thin, Plain, Recycled, Color, Thick, Coated, Label, Letter, Envelope (1 Envelope) |
| Standard Interface | Usb 2.0 X2 (Host), Usb 2.0 X1 (Device) High-Speed, 10/100/1000base-T Ethernet (Network), Wi-Fi 802.11b/G/N, Wi-Fi® Direct Connection, Near Field Communication |
| Wifi Authentication Methods | Wi-Fi Infrastructure Mode: Wep 64/128 Bit, Wpa-Psk (Tkip/Aes), Wpa2-Psk (Aes) Wi-Fi Access Point: Wpa2-Psk (Aes) |
| Mobile Functions | Apple® Airprint,® Canon Print Business1, Mopria™ Print Service, Google Cloud Print™6 |
| Network Management Protocols | Ip/Mac Address Filtering, Ipsec, Tls Encrypted Communication, Snmp V3.0, Ieee 802.1x(Wired Only), Ipv6, Smtp Authentication, Pop Authentication, Pop Authentication Before Smtp |
| Os Compatibility | Windows 7/Windows 8.1/Windows 10/Windows Server 2008/Windows Server 2008 R2/Windows Server 2012/Windows Server 2012 R2/Windows Server 2016 / Mac Os X V10.9.5 (Or Later) |
| Power Consumption | Maximum: Approx. 1490 W Standby: Approx. 19.6 W Sleep Mode: Approx. 0.6 W |
| Typical Energy Consumption | 1.1 Kwh Power Requirements: Ac 120-127 V:6.5 A, 60 Hz Standards: Energy Star® Qualified, Rated Epeat Silver 3 Operating Environment: Temperature: 50 To 86° F Humidity: 20 To 80% Rh (No Condensation) |
| Dimensions | Standard (Desktop): 17.5" X 23.1" X 23.3" (445 Mm X 587 Mm X 592 Mm) Box: 19.1" X 18.8" X 15.2" (485 Mm X 478 Mm X 386 Mm) |
| Unit Weight Without With Cartridge | Unit: Approx. 47.8 Lb. (22.0 Kg) Boxed Weight: Approx. 53.5 Lb.(24.0 Kg) 4 |
| Lcd Display | 5" Color Touch Panel |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
