Color imageCLASS LBP622Cdw
- imageCLASS LBP622Cdw product
- Cartridge 054 CMY Starter: 680 Page Yield, Black Starter: 910 Page Yield
- Power Cord
- Starter Guide
- User Software DVD-ROM
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Color imageCLASS LBP622Cdw is registered EPEAT Silver.
Workflow Efficiency
- Supports various mobile printing solutions.1
- Out-of-the-box, standard two-sided printing helps to reduce paper consumption.
- Designed for small print jobs with first-print time as fast as 10.3 seconds.
User Experience
- High-capacity, all-in-one cartridge helps reduce overall supply costs.
- Canon's signature reliability and engine technologies help keep productivity high and minimize the impact on support resources.
- Create Wi-Fi® Direct hotspot from the printer to establish direct connection to mobile device(s) without the need for an external router.
Sustainability
- A combination of fusing technologies and low-melting-point toner minimizes power requirements and helps achieve low-energy consumption.
- Encourage environmentally conscious work practices by enabling settings that can help save paper and energy.
- ENERGY STAR® certified and currently rated EPEAT® Silver.2
- Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit www.cla.canon.com/cla/en/office/MobileApps.
- For current EPEAT ratings (Gold/Silver/Bronze), please visit www.cla.canon.com/cla/en/epeat.
- Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
| Printer Type | Color Laser Single Function |
| Print Speed | Up To 22 Ppm (Letter); Up To 17.9 Ppm (Legal) 3 |
| First Print Time | Approx. 10.3 Seconds |
| Printer Language | UFR II |
| Print Resolution | 600 X 600 (Dpi) |
| Maximum Print Size | Cassettes: Letter, Legal, Statement, Executive, Envelope: COM10, Monarch, C5, DL, Custom (Min. 3" X 5" To Max. 8.5" X 14") Manual Feed Slot: Letter, Legal, Statement, Executive Envelope: COM10, Monarch, C5, DL Custom (Min. 3" X 5" To Max. 8.5" X 14") |
| Duplex Print | Automatic (Standard) |
| Print Memory | 1 GB |
| Standard Paper Source | Standard: 250-Sheet Paper Cassette, 1-Sheet Stack Bypass |
| Paper Output | Standard: 75 Sheets |
| Paper Weight | Cassette: 16 Lb. Bond To 53 Lb. Bond ( 60 To 200 G/M2) Manual Feed Slot: 16 Lb. Bond To 53 Lb. Bond ( 60 To 200 G/M2) |
| Media Sizes | Cassettes: Letter, Legal, Statement, Executive, Envelope: COM10, Monarch, C5, DL, Custom (Min. 3" X 5" To Max. 8.5" X 14") Manual Feed Slot: Letter, Legal, Statement, Executive Envelope: COM10, Monarch, C5, DL Custom (Min. 3" X 5" To Max. 8.5" X 14") |
| Media Types | Cassettes: Thin, Plain, Recycled, Color, Thick, Coated, Label, Letter, Envelope (10 Envelopes) Manual Feed Slot: Thin, Plain, Recycled, Color, Thick, Coated, Label, Letter, Envelope (1 Envelope) |
| Standard Interface | USB 2.0 X2 (Host), USB 2.0 X1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/G/N, Wi-Fi® Direct Connection |
| Wifi Authentication Methods | Wi-Fi Infrastructure Mode: WEP 64/128 Bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES) Wi-Fi Access Point: WPA2-PSK (AES) |
| Mobile Functions | Apple® AirPrint,® Canon PRINT Business1, Mopria™ Print Service, Google Cloud Print™5 |
| Network Management Protocols | IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X(Wired Only), IPv6, SMTP Authentication, POP Authentication, POP Authentication Before SMTP |
| Os Compatibility | Windows 7/Windows 8.1/Windows 10/Windows Server 2008/Windows Server 2008 R2/Windows Server 2012/ Windows Server 2012 R2/Windows Server 2016 / Mac OS X V10.9.5 (Or Later) |
| Power Consumption | Maximum: Approx. 900 W Standby: Approx. 7.9 W Sleep Mode: Approx. 0.7 W |
| Typical Energy Consumption | 0.6 KWh Power Requirements: AC 120-127 V:6.5 A, 60 Hz Standards: ENERGY STAR® Qualified, Rated EPEAT Silver 2 Operating Environment: Temperature: 50 To 86° F Humidity: 20 To 80% RH (No Condensation) |
| Dimensions | Standard (Desktop): 17.2" X 16.7" X 11.5" (437 Mm X 425 Mm X 292 Mm) |
| Unit Weight Without With Cartridge | Unit: Approx. 35.2 Lb. (16.0 Kg) Boxed Weight: Approx. 41.8 Lb. (19.0 Kg) |
| Lcd Display | 5-Line LCD |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
