Color imageCLASS LBP612Cdw
- Color imageCLASS LBP612Cdw Product
- Cartridge 045 CMY: Starter 700 Yield / K: Standard 1,400 Yield (ISO / IEC Standard)
- Power Cord
- Starter Guide
- User Software DVD-ROM
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The Canon Color imageCLASS LBP612Cdw offers feature rich capabilities in a high quality, reliable printer that is ideal for any office environment. This single function, color laser printer with easy to use features and various mobile solutions gives your business the support and efficiency it deserves.
Your professional quality color documents are printed at speeds of up to 19 pages per minute1 in both color and black and white with a quick first print time of approximately 11 seconds2. Get high quality, crisp and bold color business documents as well as photos using V2 (Vivid and Vibrant) Color Technology, which increases image sharpness and color vibrancy. Eco-conscious, duplex print saves you time, paper, and related costs, as well as limits interruptions.
The 5-line, black and white LCD panel allows you to navigate through the menu seamlessly and customize the settings to access the features you use most.
The LBP612Cdw has wireless connectivity, increasing your productivity and allowing you to print from almost anywhere in your home or office4. The device also has built in Wi-Fi® Direct Connection capability6, enabling easy connection to mobile devices without a router. Enjoy a variety of easy to use mobile features for printing on the go using your compatible mobile device, such as Canon PRINT Business7, Apple® AirPrint®8, Mopria™ Print Service9 and Google Cloud Print™10.
Manage device usage and color access for up to 300 IDs, using password protected Department ID Management. USB Direct Print allows you to print from that USB in JPEG, TIFF and PDF formats.
The LBP612Cdw provides generous paper capacity to keep up with your fast paced business output needs. With the front-loading 150-sheet paper cassette and 1-sheet manual feed slot, your paper handling requirements are covered.3
The LBP612Cdw uses approximately 0.7 watts of energy in Energy Saver Mode, helping you save money on energy costs. The Single Cartridge System combines the toner and drum into 1 unit, making replacement of cartridges simple. High-capacity toner options keep you printing longer, with limited toner replacements so you can keep pace with your busy output needs. The LBP612Cdw uses Canon GENUINE Toner, Cartridge 045 CMYK (CMY yields 1,300 sheets / K yields 1,400 sheets, ISO/IEC standard) and Cartridge 045 Hi Capacity CMYK (CMY yields 2,200 sheets / K yields 2,800 sheets, ISO/IEC standard).
Print at speeds of up to 19 pages per minute, with your first print in your hands in 12 seconds or less.
Easily connect your mobile devices without a router using Wi-Fi® Direct Connection.
V (Vivid and Vibrant) Color Technology produces high-quality prints by increasing image sharpness and color vibrancy.
Print on the go with Canon PRINT Business, Apple® AirPrint®, Mopria™ Print Service, and Google Cloud Print™.
Navigate through all the features with the user-friendly 5-line, LCD Panel.
Eco-conscious, two-sided printing out of the box saves paper and related cost.
Easily print to your USB flash drive in JPEG, TIFF and PDF formats.
Low energy consumption; uses approximately 0.7 W in Energy Saver Mode.
Hi Capacity Toner Options keep up with your printing needs and limit toner replacement interruptions.
100% U.S. Based Service and Support team provides friendly, expert help for every level of experience.
2. May vary depending on the output environment.
3. Based on 20 lb. bond paper.
4. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
5. Requires an Android mobile device with NFC hardware running Android 4.0 or later, and the Canon Print Business app, available for free at Google Play. Canon Print Business app must be open to use tap and print functionality.
6. Wi-Fi®; is a registered trademark of the Wi-Fi Alliance®;. The Wi-Fi CERTIFIED™ Logo is a certification mark of the Wi-Fi Alliance®;.
7. Canon PRINT Business is a free app available on the App Store®; and Google Play™ Store. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Users of Canon Mobile Printing can simply update the app to use Canon PRINT Business. Users who have installed Canon Mobile Scanning for Business should install Canon PRINT Business on their compatible device. After Canon PRINT Business is installed, users can re-register their Canon Mobile Scanning for Business device list and local documents. Android is a trademark of Google Inc. App Store is a service mark of Apple Inc. iPhone, iPad Air, iPad, iPad mini, are trademarks of Apple Inc., registered in the U.S. and other countries. iOS is a trademark or registered trademark of Cisco in the United States and other countries and is used under license.
8. AirPrint functionality requires an iPad, iPad Mini, iPad 2, the new iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base Station, or Time Capsule is not supported.
9. Mopria Print Service, available for free at the Google Play Store, requires a compatible Android KitKat 4.4 smartphone or tablet. The printer must be either wirelessly connected to the network router or with an Ethernet cable. The mobile device and printer must be connected to the same network.
10. Google Cloud Print requires an Internet connection and Google Account. Printer firmware update may be necessary for Google Cloud Print™ function. Certain exceptions may apply. A PC running Windows XP or later or a Mac running OS 10.4.11 or later and USB cable are required to perform firmware update.
11. Warranty program is subject to certain conditions and restrictions. See the warranty card for details.
| Printer Type | Color, Wireless, Duplex Laser Printer |
| Print Speed | Up To 19 Ppm (1-Sided Plain Paper Letter), Up To 11 Ppm (2-Sided Plain Paper Letter)1 (Bw / Color, Letter) |
| First Print Time | Approximately 10.7 Seconds (Bw), 11.9 Seconds (Color), Letter2 |
| Printer Language | UFR II |
| Print Resolution | Up To 600 X 600 Dpi, 1200 X 1200 Dpi Equivalent |
| Maximum Print Size | Up To Legal |
| Duplex Print | Yes |
| Print Modes | Poster, Booklet, Watermark, Toner Saver, Page Composer |
| Print Memory | 1 GB |
| Direct Print From Usb | JPEG, TIFF, PDF |
| Standard Paper Source | 150-Sheet Cassette Plus 1-Sheet Manual Feed Slot3 |
| Paper Output | 100 Sheets (Face Down) |
| Paper Weight | 14-43 Lb. Bond (Cassette/Manual Feed Slot) |
| Media Sizes | Letter, Legal, A4, A5, B5, Statement, Executive |
| Media Types | Plain / Heavy / Recycled / Color Paper, Label, Postcard, Envelope |
| Envelope Capacity | 1 Envelope (Manual Feed Slot) |
| Envelope Types | Com 10, Monarch, DL, C5 |
| Standard Interface | USB Device 2.0 Hi-Speed, 10/100/1000 Base-T Ethernet (Network), Wi-Fi 802.11 B/G/N4 |
| Wifi Access Mode | Infrastructure Mode, WPS Easy Setup, Wi-Fi® Direct Connection5 |
| Wifi Authentication Methods | WEP 64/128 Bit, WPA-PSK (TKIP, AES), WPA2-PSK (AES) |
| Wps Easy Setup Support Methods | Push-Button Mode, PIN Code Mode |
| Mobile Functions | Canon PRINT Business6, Apple® AirPrint®7, Mopria™ Print Service8, Google Cloud Print™9 |
| Embedded Web Server Remote Ui | IE 9.0 Or Higher, Safari 5.0.6 Or Higher |
| Print Protocols | LPD, RAW, WSD-Print (IPv4, IPv6) |
| Tcp Ip Set Of Application Services | Bonjour (MDNS), HTTP, HTTPS, DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6) |
| Network Management Protocols | SNMPv1, SNMPv3 (IPv4, IPv6) |
| Os Compatibility | Windows® 10, 8.1, 8, 7, Windows Server® 2016, Windows Server® 2012, 2012 R2, 2008 R2, 2008,Windows Vista®, Mac OS 10.7.5 Or Later |
| Cable Included | Power Cord (USB Not Included) |
| Bundled Software | Printer Driver |
| Power Consumption | Approx: 340 W (During Operation), 10.2 W (Standby), Energy Saver Mode: 0.7 W (USB/Wired/Wireless)
| Typical Energy Consumption | 0.5 KWh |
| Dimensions | 17" (W) X 16.5" (D) X 10.8" (H) |
| Unit Weight Without With Cartridge | 29.7 Lbs. (W/O Cartridge), 34.1 Lbs. (W/Cartridge) |
| Package Weight | Approx. 40 Lbs. |
| Cartridge Type | Cartridge 045 CMYK (CMY Yields 1,300 Sheets / K Yields 1,400 Sheets, ISO/IEC Standard) And Cartridge 045 Hi Capacity CMYK (CMY Yields 2,200 Sheets / K Yields 2,800 Sheets, ISO/IEC Standard). Single Cartridge System |
| Lcd Display | 5-Line, BW LCD |
| Duty Cycle | Up To 30,000 Pages Per Month |
| Department Id Management | Up To 300 IDs |
| Security | IP / MAC Address Filtering, SNMPv3, SSL (HTTPS/IPPS), IEEE802.1x |
| Languages | English, Japanese, French, Spanish, German, Italian, Portuguese, Chinese, Korean |
Cartridge 045 Black
1,400 sheets, ISO / IEC Standard
Cartridge 045 Cyan
1,300 sheets, ISO / IEC Standard
Cartridge 045 Yellow
Cartridge 045 Magenta Hi-Capacity
Yields approx. 2,200 pages based on ISO/IEC Standard.
Cartridge 045 Black Hi-Capacity
Yields approx. 2,800 pages based on ISO/IEC Standard.
Cartridge 045 Cyan Hi-Capacity
Cartridge 045 Yellow Hi-Capacity
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
