CanoScan LIDE 400
- CanoScan LiDE 400 Color Image Scanner
- Setup CD
- USB 2.0 Type-C™ Cable (USB A to Type-C)
- Vertical Stand (Clip-on)
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
HIGH-QUALITY, FAST SCANNING MADE EASY
8 SECOND HIGH-SPEED SCANNING & SEND TO THE CLOUD
Enjoy high speed scanning in as fast as 8 seconds, with the included USB Type-C™ cable. With USB Type-C™ the CanoScan LiDE 400 has one cable for data and power. Even Scan and send your files right to Cloud services, with Send to Cloud feature. With Send to Cloud you can easily upload your photos and documents right to Cloud services like Microsoft OneDrive™ and Dropbox®.
4800 x 4800 dpi Resolution for High Quality Scanning
Preserve detailed photos and images thanks to 4800 x 4800 dpi resolution, and with image enhancements, such as color restore and dust removal, your photos will continue to look great..
The CanoScan LiDE 400 is even able to scan upright - saving desk space without sacrificing quality.
Easy Scanning with Five 'EZ' Buttons
Enjoy the ultimate ease of use with the 5 'EZ' Buttons. With Auto Scan Mode, the scanner automatically adjusts settings by detecting what you are scanning. With the built-in PDF buttons, you can easily scan and save multi-page PDF's that are editable and searchable with OCR.
- Color document scan speed (Color Letter/A4 300dpi) is measured with ISO/IEC 29183 Target-A. Color photo scan speed: (Color 4"x6" 300 dpi) is measured with ISO/JIS SCID No.2. Scan speed indicates the time measured between pressing the scan button of the scanner driver and when the on-screen status display turns off. Scan speed is measured using a USB 3.0 interface using the included USB cable on a PC, and may vary depending on system configuration, interface, software, scan mode settings and document size etc.
- Optical resolution is a measure of maximum hardware sampling resolution, based on ISO 14473 standard. Increasing the scanning resolution will limit the maximum possible scanning area.
- Auto Scan Mode is available when scanning at a computer using IJ Scan Utility or IJ Scan Utility Lite software and selecting the 1-click feature then "Save to PC." or using the Auto Scan Mode 'EZ' button on select models. Auto Scan Mode is not available in upright scanning mode.
- Extracting text from scanned images (OCR (Optical Character Recognition)) is only available when extracting text when scanning via Document, Custom, or Driver settings using IJ Scan Utility/IJ Scan Utility Litesoftware on a compatible operating system. For more information, please see the product User Manual.
- Internet Connection Required. Requires active Cloud service account, and required software must be installed on computer for "Send To Cloud" function to work with those services.
- To install using Windows®; OS, .NET Framework 4 is required. Compatible still image formats are PDF (created using Canon PDF Creator only), JPEG (Exif), TIFF, and PNG. Compatible video formats are MOV (fromselect Canon digital cameras only) and MP4 (from select Canon digital camcorders only).
- Operation can only be guaranteed on a PC with pre-installed Windows 10, Windows 8.1, Windows 7 SP1.
- Internet Connection required during software installation. For full compatibility macOS v10.12.1 or later is recommended.
- Scanning on the Linux operating systems requires "ScanGear MP for Linux" scanner driver installed. Certain exceptions may apply.
| Scanner Type | Flatbed |
| Scanning Element | Contact Image Sensor (CIS) |
| Light Source | Three Color (RBG) LED |
| Features | 5 'EZ' Buttons, Advanced Z-Lid™ Expansion Top, Auto Dust & Scratch Reduction (Windows Only), Auto Document Fix (Windows Only), Auto Scan Mode3, Digital Filing, Fading Correction (Windows Only), Grain Correction (Windows Only), Gutter Shadow Correction (Windows Only), High-Speed Scanning1, Image Correction, Low Power Consumption, Multi-Page PDF, OCR (Optical Character Recognition)4, One Cable For Data & Power, Send To Cloud5, Upright Scanning |
| Scanner Buttons | 5 'EZ' Buttons; Auto Scan, Copy, PDF X2 (Scan Start, Scan Finish), Send |
| Max Resolution Choice | Optical |
| Max Resolution Text | 4800 X 4800 Dpi2 |
| Max Resolution Choice | Interpolated |
| Max Resolution Text | 19,200 X 19,200 Dpi2 |
| Scanning Speed | Document: Approx. 8 Seconds (300 Dpi/Letter Size/Color) 4"X6"1 Photo: Approx. 4 Seconds (300 Dpi/Color)1 |
| Scanning Mode | Color: 48-Bit Internal / 48-Bit Or 24-Bit External Grayscale: 16-Bit Internal / 8-Bit External |
| Max Document Size | 8.5" X 11.7" (Letter/A4) |
| Os Compatibility | Windows: 7 Windows® 10, Windows 8.1, Windows 7 SP1 Mac:8 Mac OS® X V10.10.5 - MacOS V10.13 (High Sierra) Linux®:9 Requires ScanGear MP Driver Installed |
| Power Requirements | USB Type-C™ (One Cable For Data & Power) |
| Software | (WINDOWS7 /MAC8/LINUX9) CanoScan LiDE 400 Color Image Scanner Driver IJ Scan Utility (Windows) / IJ Scan Utility Lite (Mac) Auto Scan, Document Scan, Photo Scan, Custom Scan, Stitch Scan, And OCR (Optical Character Recognition)4 ScanGear MP Driver9 Quick Menu |
| Power Source | USB Type-C™ (One Cable For Data & Power) |
| Max Power Consumption | 4.5 W (0.3 W Standby) |
| Operating Temperature | 41 - 95°F (Without Condensation) |
| Operating Humidity | 10 - 90% (Relative Humidity) |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
