CanoScan 5600F
- CanoScan 5600F
- Power Cord
- USB Cable
- Film Guide:
35mm film strip/mounted slides - Documentation kit:
Setup Software & User's Guide CD-ROM
Quick Start Guide
Contact information Sheet
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
High-Quality 4800 dpi1 Scanner for Documents and Films.
You're going to love the results, with outstanding color dpi resolution up to 4800 x 9600. Built-in FARE® 3.0 retouching technology helps to enhance your final images, even correcting for dust, scratches, and backlighting on photos. For convenience, you can batch-scan up to six 35mm frames or four 35mm slides at once.
Smart Scanning - The new Auto Scan feature makes scanning anything even easier than before. It actually detects the type of original you're scanning - whether it's a photo, business card, personal notebook or form-then automatically scans, processes and saves the image in the appropriate format. All at the press of just one button.
Scan Film and Slides - The built-in backlight and included film guide let you simultaneously scan up to six 35mm negative frames or up to four 35mm slides.
Generation Green is Canon's new environmental initiative. This program encompasses eligible Scanners, PIXMA Inkjet Printers and imageCLASS laser printers. Generation Green is designed to provide business partners, customers and consumers a way to learn about the environmentally-friendly approach that Canon is taking to design many of its current and future products and solutions; for example, possible cost savings through energy efficiency. The CS 5600F has the following Generation Green characteristics:
- White LED - The white LED allows the scanning unit to be smaller and have no warm-up time, resulting in lower energy consumption. This means that you can start scanning immediately (excludes film scanning).
- ENERGY STAR - Qualified products are 25% more efficient than conventional models. By using less energy, these products reduce greenhouse gas emissions and save energy as well as money.
- RoHS Compliance - This is a directive from the European Union that restricts the use of hazardous materials found in electronic products. This product restricts the the use of cadmium, mercury, lead, hexavalent chromium, Polybrominated Biphenyls (PBB) and Polybrominated Diphenyl Ethers (PBDE).
- Hardware Recycling Program - Canon is committed to the world community and the belief that we are building a better world for future generations. We want to work with our customers to ensure appropriate recycling of products to help improve the environment and our local communities.
- Refurbishing Program - The Canon refurbishing facility manages all waste stream processes for Canon products, so Canon has full control over recovery and salvage for Canon U.S.A. products, not third-party vendors.
To learn more about Generation Green, visit www.usa.canon.com/green
- Optical resolution is a measure of maximum hardware sampling, based on ISO 14473 standard.
- Color document scan speed is measured with ISO/IEC 24712 Newsletter. Scan speed indicates the time measured between pressing the scan button of the scanner driver and when the on-screen status display turns off. Scan speed may vary depending on system configuration, interface, software, scan mode settings and document size, etc.
- The time required for the light source to reach sufficient operating temperature. Film scanning excluded.
- Specifications are subject to change without notice.
- System requirements vary by application.
| Scanner Type | Flatbed Color Image Scanner |
| Scanning Element | Charge-Coupled Device (CCD) 6-Line Color |
| Light Source | White LED (Reflectives), Cold Cathode Fluorescent Lamp (CCFL) Film |
| Features | White LED, Zero Warm-Up Time, Automatic Document Recognition, 7 EZ Buttons, Auto Dust & Scratch Reduction, Backlit Film Scan, Fading/Grain/Backlight Correction, Auto Scan Mode, Convenient Filing Function (PDF Function), PDF Password, Gutter Shadow Correction, High-Speed Scanning |
| Scanner Buttons | 7 Buttons PDFx4, COPY, SCAN, PHOTO/FILM, E-MAIL |
| Max Resolution Choice | Optical |
| Max Resolution Text | 4800 Dpi X 9600 Dpi2 |
| Max Resolution Choice | Interpolated |
| Max Resolution Text | 19,200 Dpi X 19,200 Dpi |
| Scanning Speed | Scanning Speed*3 Color Color/A4/300dpi: Approx. 11 Sec. Scanning Speed*4 Grayscale, B&W 14.6msec/Line (4800 Dpi) 14.6msec/Line (2400 Dpi) 9.7msec/Line (1200 Dpi) 3.7msec/Line (600 Dpi) 1.8msec/Line (300 Dpi) Color" 14.6msec/Line (4800 Dpi) 14.6msec/Line (2400 Dpi) 9.7msec/Line (1200 Dpi) 3.7msec/Line (600 Dpi) 1.8msec/Line (300 Dpi) Scanning Speed*4 (Film)" Color, Grayscale, B&W 1.8 ~ 58.4 Msec/Line |
| Scanning Mode | Color: 48-Bit Internal Input (16 Bits For Each Color) 48 Or 24-Bit External Output(16 Bits Or 8 Bits For Each Color) Grayscale: 48 Bits Internal Input (16 Bits For Each Color) 16 Bits (Film Scanning Only) Or 8 Bits External Output |
| Max Document Size | A4/Letter: 216 X 297 Mm (8.5 X 11.7 In.) |
| Max Film Size | Film Type/No. Of Frames 35 Mm Strip (Negative/Positive)/6 Frames, Slide (Negative/Positive)/4 Frames |
| Interface | USB 2.0 Hi-Speed |
| Dimensions W X D X H | 271mm(W) X 492mm (D) X 96mm (H) (10.7" (W) X 19.4" (D) X 3.8" (H)) |
| Weight | Approx. 4.3 Kg (9.5 Lbs.). |
| Os Compatibility | Windows Vista®, Windows XP/2000 And Mac OS® X V.10.3.9- 10.5.X5 |
| Software | Setup Software And User's Guide CD-ROM, MP Navigator EX,Solution Menu, ArcSoft® PhotoStudio® |
| Power Source | AC Adapter |
| Max Power Consumption | In Operation: 19 Watts Maximum, Stand-By: 3.2 Watts) |
| Operating Temperature | 10°C- 35°C (50°F - 95°F) |
| Operating Humidity | 10% To 90% RH (20% To 80% RH For Film Scanning), Without Condensation Formation |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
